Question about Timex Watches
I would like to know how to change the digital display on my TIMEX V CELL watch. The analogue part functions perfectly, but i cannot change the Day- Date function. I assume that the numbers, reading from left to right. are -month-date- day. The arrow blinks on d-d. The 2 buttons on the left hand side do not seem to operate. The tiny one on the rigfht hand side does change functions. I am a 78 yr old wrinkly, and even my more modern family can't figure out the combinations of it's workings. I am not timing the Olympic Games, but would like to show off what a Timex can do. Thank you all. Pete.
  • barpetrob Oct 13, 2010
    In addition the day and date operate ok, still I suppose they should as itis hooked up to the battery. I have had the back off and the buttons operate the contacts, but are quite stiff. Whilst trying to find out a possible sequence, the day changed, but I have been unable to repeat this magic moment.
    President:
  • 2,501 Answers
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Posted on Oct 13, 2010
  • 3,083 Answers
If the date won't change, chances are the button has some dust that's worked it's way in, and possibly a bit of oxidation has occurred with the switch. I have an old Seiko from the early 80's that has 4 buttons on it, and I had the same problem, so I took it apart and cleaned the switches with electrical contact cleaner (a spray cleaner), and got them all working again. I don't really recommend anyone doing this, as it is tedious, and so I would recommend you take it to a reputable watch repair service.
Most certainly it's bad contact with the "select" switch, and a good cleaning should get it in working order.
Good luck, and hope this helps.
Posted on Oct 10, 2010
How to set time on a 1440 timex watch
Hi tsgoode99,
To set the digital time and date on your Timex, please follow the steps below.
Timex Digital Watch
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Dec 25, 2010 | Timex 1440 Nylon watch
How do you set the time on the timex 440 sports watch
Hi markie_d,
Timex Digital Watch
Hope it helps.
Oct 31, 2010 | Timex 1440 Nylon watch
I have a timex watch with both analogue and digital.... only the digital is working after a battery change. What do you recommend
Take the battery out again and let the watch "rest" for a couple of hours without the battery. That sometimes resets the Quartz mechanism, and will allow a clean restart. Also, refer to the following info if needed.
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Sep 05, 2010 | Timex Watches
Setting Timex 1440 sports watch
mcdevito75 here, For now, you need to know 2 buttons, the MODE and SET buttons, First press the MODE button, you may have to hold it in 2--3 seconds, see the display Blinking, now press the SET button for each function, (hour, minute etc). press MODE after each function is set, after all is set Press MODE for steady display. Here"s Timex Contact number for a manual, 800-448-4639
Jul 12, 2010 | Timex 1440 watch
I have been given a philip persio watch, (no idea which model) it has an analogue display and a digital display. the digital works perfectly but the analogue wont start any ideas
many of these watches require 2 batteries. One for the analog and one for the digital. I would contact a jewelry store to make sure they will change your batteries; since the watch was free to you it will surely be worth the price of new batteries to get it working.
Also, some models do take only one battery but if it is not at a full charge you may have the issue you described.
If not a battery issue, then there are other detailed steps to follow (the jeweler should be able to help you.)
Note: I recommend contacting an independant jeweler (non-chain and non-mall store) because most non-independants will not change batteries in watches they don't sell.
Oct 31, 2009 | Watches
We don't know how to set the 1440 sports watch
Hi katbil1,
Timex Digital Watch
Hope it helps.
Oct 24, 2009 | Timex 1440 Nylon watch
Watches Logo
47 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
David Ellis Rhea
Are you a Timex Watch Expert? Answer questions, earn points and help others
