Question about Fuji Cameras
The lens on my Fuji Finepix s8000fd camera is stuck in the barrel. I suspect its been dropped. When I switch camera on I can hear the mechanisms trying to work, but the lens won;t move.
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Fuji service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the speedy and free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 10, 2010
Lens become stuck
Do you know what caused the lens to get stuck? Did someone drop it, or was the camera a long time not used?
Most of the time this is a mechanical problem. At least is you still can switch the camera on and get into the menus and when you still can view pictures taken.
In rare occasions, the blockage can be released with a little shock to the camera. Never use force on a camera, or tick something against a camera. you could slap your hand, holding the camera, but not hard. But when the blockage is caused by a broken gear, noting will help. The camera should go to a repair store.
Before you do, be sure the battery is fully charged. An old battery, could cause trouble too. More often than you can think of.
Nov 24, 2013 | Fujifilm Finepix S2980
Fuji FinePix S8000fd Digital Camera I have
Hello :
Lens error is the most common failure in digital cameras . it seems The internal coupling of the zoom lens is somewhat fragile, and a slight tap at the wrong time can mess up the system . or it could have been something as small as a bump while it was being carried in your pocket or even the sand or something like it can cause this problem . Anyway the problem is that you'll have to pay for repairs on it since technically it's not a camera error but something that manufacturers say it happened during usage. I recommend you to contact the manufacturer to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky . Some owners seem to have been able to solve the problem with a gentle bump to the side of the camera, or some gentle twisting on the lens itself. I don't necessarily recommend that- or, at least I would call Fuji first and see what they have to say about cost of repairs. Once you do get it fixed, put the camera in Playback mode before you switch it off so that the problem doesn't happen again.
PLEASE DON'T FORGET TO RATE !
good luck
Apr 11, 2010 | Fuji FinePix S8000fd Digital Camera
Hi, MY LENS IS STUCK AND I LIVE BETWENN CANCUN AND PLAYA DEL CARMEN.i HAVE A DIGITAL FUJI FINEPIX S1000.PlEASE HELP
The Camera must have fallen down and it Can be the barrel itself has gone bad
you can take a risk and try at home twist very slowly the lens and try to get back the original position if not then you need to replace the lenns barrel.hope this helps
Sep 01, 2009 | Fuji FinePix S1000FD Digital Camera
Hi I have a fujifilm f470 finepix camera. One
Is it just the live view from the lens that you can't see ( totally blank screen), or are the icons visible?
If it still shows the icons but no live view then I suspect the shutter mechanism is stuck over the lens inside the camera.
Have a look at the lens and see if you can see the inner lens? You may have to adjust the zoom to bring the inner lens up to the end of the lens barrel.
If it is stuck then it will require removing and inspecting / cleaning.
Aug 26, 2009 | Fuji Rod Repair Kit
Manual Fuji Finepix S8000fd
Hi - You can download the manual from the link underlined in blue below:
Finepix S8000fd
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 19, 2008 | Fuji FinePix S8000fd Digital Camera
Lens adapter needed
Get yourself a step ring, 52mm for you S8000FD, this has a thread on the end and allows filter attachments. I have an S8000FD and have since bought a step up ring, UV filter and Polariser, plus another lens cap which fits on to the end via a pinch mechanism rather than clamping like the one provided by Fuji.
May 23, 2008 | Fuji FinePix S8000fd Digital Camera
Lens adapter
Hi
I do not believe that it is possible to use a lens adapter with this camera or even filters.
The lens that comes with it has a wide focal range and the camera itseld is sold as a compact.
You may need to look at a fully digital SLR to get this feature
Apr 22, 2008 | Fuji FinePix S8000fd Digital Camera
Cameras Logo
101 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
