Question about Kodak EasyShare M1033 Digital Camera
Camera lens is stuck out and wont retract. Camera will not turn on. It will charge but even though it seems to be fully charged it still wont retract the lens and turn on.
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Kodak service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the speedy and free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 10, 2010
My lens isis stuck and will not retract
Camera requires servicing, which may not be financially viable. If this is the case, replace the camera.
Jul 15, 2016 | Ricoh Caplio R7 Digital Camera
When I power up the camera the lens opens and immediately retracts and the camera shuts off. I've attempted to push every button while turning on the camera to no avail. I also held onto the lens when it...
Have you made sure that the batteries are LiIon and fully charged? I had a similar problem with a Kodak Easyshare camera that required the higher voltage LiIon battery pack rather than alkaline AAs which will fit in there but is not exactly right.
Feb 09, 2011 | Kodak EASYSHARE M763 Digital Camera
Lens wont extract
It could be that there's a grit of sand that got stuck between your lens' barrel and the camera's base, preventing the lens to retract freely. So here is what you do. Make sure your battery is fully charged. With your camera turned OFF, hold the camera on your right hand with the lens facing the ground. Then hit the camera's base on your left palm as you push the button to turn on the camera. You might have to do this a few times. If the above solution does not work, you might need to blow a canned air around the sides of the lens of your camera. The idea here is to remove that grit out of the camera.
Please let me know how this goes. Thank you for using FixYa.
Jan 31, 2011 | Sanyo Cameras
My camera will not stay on is off and stuck with lens out
If the lens doesn't retract on most digital camera the camera also will not turn ON. It is connection or wiring between camera power and camera lens.
What Kodak Rep will ask you to do are:
1. Remove the battery and the memory card of the camera
2. Check if your using a recommended battery and if its new or fully charge. batteries for Z1275 are Ni-MH rechargeable; CRV3 Lithium; 2AA Lithium
3. Insert the batteries back in the camera in correctly
4. Set the camera in Auto mode (its the camera icon on the dialing mode of the camera)
5. Try to turn it ON
If still will not turn ON and the lens will not retract
6. If your using a rechargeable battery Kodak Rep will ask you to charge the battery until its fully charge.
If your using a disposable battery they will ask you to try to use a new battery out from the box.
After all those steps still the camera failed to work, it will be send for repair. The number of the Kodak support line is 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z1275 Digital Camera
Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at mike@digitalcamrepair.com
Feb 26, 2009 | Casio Exilim EX-S600 Digital Camera
Kodak EasyShare One lens won't open - camera cycles on/off
I had the same problem. Even though I was keeping the camera on the dock all of the time to charge it, the solution was very simple - get a new battery for inside the camera.
I bought new ones at a greatly reduced price on eBay. Now I carry one with me wherever I go in case the battery wears out/down.
I shoot a lot of videos, so it really takes a lot out of the batteries.
Dec 15, 2008 | Kodak EasyShare One Digital Camera
Kodak dx7630
turn the lens slightly towards the way it is supposed to retract.
Sep 25, 2008 | Kodak EasyShare DX7630 Digital Camera
I need help!
try to remove the battery and let the camera sit for a few minutes and reinsert the battery to reset the camera
Sep 02, 2008 | Kodak Easyshare M753 Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Camera wont turn on, intermittent red power coming on
This may or may not work (it's primarily a trick for certain Canon cameras with similar symptoms). Remove the cameras battery, then remove the memory card. Insert a BRAND NEW or fully charged rechargeable batteries. DO NOT insert the memory card. Instead, just turn on the camera. If the lens retracts, turn off the camera, insert the memory card, then restart the camera.
If this doesn't work, here are some other things to try. But don't get your hopes up, as they only seem to work for little less than half the cameras with similar problems:
Jan 08, 2008 | Fuji FinePix V10 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
553 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
