Question about Margaritaville Frozen Concoction (DM1000) Blender
The liquid was put into the container. The switch was turned on and the ice was crushed and being dropped into the mixture. When the bottom blade started to blend the mixture everything started to leak out beteen the grreen base and the clear container. We had to take the top green lid off first, then lift up the clear piece with the blade in order to get it over to the sink. The green base did not come with it. This happened twice.
2 Suggested Answers
SOURCE: Can not get Margaritaville blender to start
look for rocker switch left side of machine near bottom
Posted on Jul 01, 2009
Motor leaking dark liquid
Hi, my wife and I purchased the Health master blender about 6yrs ago. I recently noticed that the liquid was leaking from the bottom of the container. The blade is totally loose. How can I tighten it if at al?
Apr 14, 2014 | Montel Williams Living Well Healthmaster...
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
Blender leaks
Well, that's not good. Call the manufacturer and they should be willing to dend you one. Good luck.
Jul 21, 2009 | VillaWare 5785 Smoothee Bar Work Top...
Jun 30, 2009 | Margaritaville Frozen Concoction (DM1000)...
Need instructions on how to use.
Go to GE website or any brand and look for user manuals. They have recipes and instructions. And it's all free information! Try these:
http://www.gehousewares.com/products/840079000_1068232922783.pdf
http://www.gehousewares.com/Product_Search.aspx then select FOOD PREP, then BLENDER, then SEARCH and there will be about 10 user manuals you can browse for instructions and recipes. Instructions for blenders are pretty much the same. Don't put too much in the jar, no more than 3/4 full - I keep mine to 1/2 full. DOn't make recipe too thick or you will stress the motor - add water, milk or other liquid. Don't do ice cubes unless your machine is made for ice crushing. Good luck!
Jun 13, 2009 | Blenders
Osterizer blender problem
Is the black plastic part, seal, and glass portion snugly fitted together? If so, it's likely that the black plastic part isn't making contact with the pin. On mine I have to turn it about a quarter turn to lock it to the motor/ drive pin.
If I have a hard object such as ice cubes too firmed placed in the blender against the blade and the glass, I shake the container to loosen the materials and reseat it onto the drive pin as mentioned above.
May 09, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
Need manual for Bravetti Slushie Maker
Try this link: http://www.euro-pro.com/europro/manuals/SM409B.pdf
Sep 08, 2007 | Blenders
Blade turns with difficulty
Check the blade assembly it may be worn out.
Mar 27, 2007 | Vitamix 5000 Work Top Blender
Margaritaville Frozen Concoction (DM1000) Blender Logo
213 people viewed this question
Top Margaritaville Blenders Experts
john h
Tom Chichester
Are you a Margaritaville Blender Expert? Answer questions, earn points and help others
