Question about JVC Audio Players & Recorders
I think i burn my JVC RX-D301S i turn the volume really high an now it doesnt turn on how can i fix it? where can i get the parts?
  • rieslok May 31, 2008
    i think i blew my speaker outputs an it doesnt turn on. when i try turning it on it just turns off
    Brigadier General:
  • 6,966 Answers
If what you mean by "doesnt turn on" that there is no display, no light indicators, generally dead, then chances are that a fuse or some components of the power supply section has failed. If on the other hand, you are referring to a constant standby, there is indicator of power coming in but not switching to normal mode, then the possibility is that the built-in protection circuitry is disabling normal poweron to prevent further damage. This could be caused by abnormal current flow/damage of the amplifier section.
Repairs would involve opening the unit for a look & see. A service manual or at the very least a schematic diagram would help isolating defective sections/components. This of course would also require that you be familiar with electronic components and circuitry, use of a DVM and a soldering iron. Parts could be purchased from any electronic parts store near you. Probably best would be to desolder the determined defective parts and bring them along when purchasing the parts. This in effect would be "as per sample". Alternately, you can source parts online.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 31, 2008
  • Louie  Role
    Louie Role May 31, 2008
    It might also be of help to check the speakers themselves.
  • Louie  Role
    Hi again,
    That would be the protection circuitry kicking in. Looks like you need to check the power amplifier.
    Brigadier General:
  • 3,614 Answers
What is the exact locations..?
Posted on May 30, 2008
  • micromaster
    micromaster May 30, 2008
    you need to get the part# that you will replaced and place your order in HERE, or in HERE
    Thank u
Audio Connections
here is the user manual
http://resources.jvc.com/Resources/00/00/90/LVT1321-001B.pdf
Before I start makeing connetion suggestions can you tell me what devices are currently connected to it?
Aug 07, 2008 | JVC RX-D301S Receiver
Receiver turns off as soon as it is turned on
• check for shorted power MOSFET transistor s on the main amplifier
• have them remove in pair, if it powers up
you have succeeded finding the cause, but
• recheck again for possible additional components.
these may take some time,
and i hope youll make it.
Sep 12, 2012 | JVC RX-D301S Receiver
Immediate power off anfter turning on.
Just a further note..
Before you replace the fuses, (be sure to get an identical replacement, wouldn't want to start a fire), so you remember how long ago you began to have this problem, and, if you can recall anything that might have caused it?
Hortona
Mar 25, 2009 | JVC RX-D301S Receiver
Problem: Audio Connections 2
Thanks, I got your responce. Im currently looking into it.
also, what cable box you got?
USB Wireless transmitter
the wireless transmitter use the same frequency as your wireless network and there should b a conflict. there is a way to change the frequency on the usb transmitter. once you do that, you should be ok.
Jan 02, 2008 | JVC RX-D301S Receiver
Setup configuration
Have you tried to? I would need to see a wiring block. unit to unit, labeled at each unit including the monitor. I'll bet you can do what you seek to acheive..Give me more info, I'll show you how to do it.Just a list of makes,models,serial #s. If you have all this in PDF files, shoot 'em to me.I'll draw thr lines for you.
Dec 30, 2007 | JVC RX-D301S Receiver
Jvc rx 318 receiver
The problem you describe is common to JVC amps. This control has a motor mounted on the back of the circuit card that drives the volume control up or down using the remote control for this system. The looseness of the volume control cannot be repaired. The shaft has separated from the potentiometer. I don't know if JVC has this part any longer but it has to be replaced as a unit (volume control card).
Nov 07, 2007 | JVC RX-318 Receiver
Whenever I turn receiver on, it turns off almost immediately
The amplifier blew out (probably shorted and damaged when wire was loose, and gave out under load). It won't be cheap to repair....
Sep 12, 2007 | JVC RX-D301S Receiver
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
