Question about LG RC199H DVD Recorder/VCR
My LG RC199H DVD/VCR recorder combo does not recognize video DVD's. It reads DVD's with jpeg pictures on them and plays CD's but not regular old video DVD's. Is this something I can fix? The VCR portion works fine.
  • blue356 Nov 14, 2010
    Cleaning the laser with a Q Tip and alcohol is a method I had already tried from reading previous posts. This did not work! I have two of these units doing exactly the same thing (reading everything but a video DVD) So far, no FixYa. Any other ideas short of replacing the entire drive?
    These are things most of us with this problem already know. I don't consider this a fix. Thanks anyway.
  • 2,200 Answers
This suggests a problem with the laser pick up on the unit which is failing to read the video DVD.
This may be down to a fault with the laser or a misaligned pickup but quite often it is caused by debris such as particles of dust or even the slightest accumulation or film of dirt can cause the laser lens to malfunction.
You can either clean the lens using a Q-tip and some isopropyl alcohol but this will involve opening the case on the unit to gain access to the lens or alternatively use a DVD cleaning disk such as this one.
Simply insert the disk like a normal DVD and it performs a cleaning action to the laser lens.
The Q-tip method is usually more effective but is more involved. The cleaning disk is effective on a slightly opaque lens and the disk is not expensive so you might want to try this first.
Hope it helps. Thanks for using FixYa
Posted on Nov 14, 2010
  • Radio Code Pro
    Radio Code Pro Nov 14, 2010
    Unfortunately in this case replacing the drive is the only solution.
    Also, these particular units do not seem to be very reliable when it comes down to failed lasers and drives. You would need to consider whether it is economically viable to proceed with a replacement drive and then the risk that it may fail again after a short time.
    Thanks.
  • Radio Code Pro
    I am sorry but what what would you consider a fix in this situation? Divine intervention?
    The unit has a faulty drive which is the bottom line here. The cleaning of the lens has not worked and this particular model is known to have unreliable drive components. In fact you have two of them yourself with the same complaint which supports that in your own experience.
    The fix here is to replace the drive if you want to make the unit operational again. If you choose not to replace the drive that is up to you. The unit will remain broken until you replace the drive. There is no easy push a few buttons solution.
    So with respect, the fix has been outlined but you are choosing to disregard it.
Won't read new dvd or allow it to be ejected.
Hello, you have a common problem
1. Please change the DVD you are using
2. In order to remove the existing dvd please shut down unit and power it back up
3. Please try a different DVD to see if the problem is resolved
4. If problem persists, please try a regular music cd
5. If the problem persists, you have a bad DVD PLAYER
6. IF you can at least play music, then your problem is likely the DVD itself associated with the DVD player, you may still need to change out your player.
PLEASE COME BACK FOR MORE HELP IF NEED BE, PLEASE DO NOT FORGET TO AWARD YOUR ACCEPTED ANSWER.
Jan 10, 2011 | LG RC199H DVD Recorder/VCR
Same problem.. won't read any discs..
u need to find another dvd loader thats compatible with the recorder software or you will have problems :(. best bet, seek an authorised lg agent and purchase parts from them
Jul 03, 2009 | LG RC199H DVD Recorder/VCR
Avi format files reading problem
I think its due to lack of supporting files. Normally there will be some files in the DVD other than the .Avi files. Try making a new DVD with a well known DVD making software like Nero or video editing softwares like Ulead,Adobe Premier etc.
Mar 13, 2009 | LG RC199H DVD Recorder/VCR
Dvd playback
Clean the DVD lens with isopropyl alcohol (rubbing alcohol) and a Qtip. Be careful not to press down too hard. Gently clean the lens all around. Changing Qtips if you see anty signs of debris or dirt on the tip.
Feb 06, 2009 | LG RC199H DVD Recorder/VCR
LG RC797T Won't read disks
I had this problem last year. It had to be sent back to the company to replace the entire dvd unit; however, I found that it probably had been caused by electrical surges. Once I got it back after repair (replacement) I put the best possible surge protector I could buy on it and have not had a problem with that issue again. The idea of a surge problem came about because I blew 3 Onkyo stereos while still in warranty several years ago and they did the same thing- would not read discs, would say no disc, etc. & the protector ended the problem.
Dec 19, 2008 | LG RC199H DVD Recorder/VCR
Recording to DVD recorder
I know you can copy to the VCR. but do not know if digital recording has any form of copyright protection. You can try to copy by connecting the outputs of the DVD TV to the inputs of the DVD player recorder.
Jul 24, 2008 | LG RC199H DVD Recorder/VCR
Need Manual
You can easily download a pdf of the manual from the LG site. I looked it up myself.
Nov 01, 2007 | LG RC199H DVD Recorder/VCR
LG RC199H DVD Recorder/VCR Logo
153 people viewed this question
Computer Repairing
Computer Repairing
