Question about Black & Decker Mouse Sander/Polisher
I have been using a Mouse and turned it off for a break. On resuming the job I could not turn it on again. The switch clicked but nothing. I have checked the fuse
  • 30 Answers
Sounds like it could a be switch problem. Unfortunatly I dont think there are replacement switches available for this unit because the cost of service would be would be higher than the replacement cost. If the unit is less than 2 years old it may fall under B&D's 2 year warranty (even if you do not have a recepit there is a datecode stamped on the machine.) You can find a service center though www.dewaltservicenet.com. The only question I have is, where you using or had you used the sander to sand drywall? If so, the B&D warranty is voided. Many people try to use electric sanders to sand drywall and as hard as the tool companies work to seal off the tool componant, drywall dust is so fine that it still gets through, gets caked on everything and kills the motor and switch. Unfortunatly the best way to sand drywall is with the good old sanding block.
Posted on Oct 10, 2010
My hp 2180 printer will not print. When I click on print nothing happens. I have check everything nothing happens. The photocopier works only
Hi
Maybe the print spooler service had stop. Try to stop and restart it again. Try this solution.
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
If still not printer, try to set up or add once more the printer.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 10, 2011 | HP Office Equipment & Supplies
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
How do I delete all jobs from the printer. I have 57 and chose "select all", but it does not delete??
Try to delete the print jobs while the printer is turned ON. Also, if you are using Windows, deleting print jobs is easier when the print spooler is stopped and the printer is turned ON.
  1. Click Start => Settings => Control Panel
  2. In the Control Panel window, click to open the "Administrative Tools"
  3. Double click the icon "Services" to open it.
  4. Locate the "Printer Spooler" service, click on it to select, and click the STOP button at at top. You can right click on it and click on STOP in the context menu that appears.
  5. Now turn ON your printer. It should not print the stored jobs since the spooler is stopped.
  6. Then open your printer's folder (Start => Settings => Printers and Faxes)
  7. Select all print jobs. Then press the "Del" or Delete key in your keyboard and click on YES when prompted. Another option is to select all and then under the "Document" menu, click CANCEL.
Try your luck. I hope these help.
  1. Turn your printer ON.
Feb 11, 2010 | HP Officejet J5780 All-In-One InkJet...
If I leave my computer unattended for maybe 15 min. this monitor turns itself off. Is there a way to fix that? Thanks, brumeister
Screen savers can help protect your monitor from wear by showing a constantly changing display when your computer is not being used. Screen savers can be simple, like the Blank screen saver that turns off your monitor to save energy. To change your screen saver 1. Right-click your desktop, and then click Properties.
2. In the Display Properties dialog box, click the Screen Saver tab.
3. Click the Screen saver drop-down box, and then click a screen saver.
4. Click the Preview button to see how the screen saver will appear on your monitor.
5. Move your mouse or press a key to return to the Display Properties dialog box. To try a different screen saver, return to step 3. 6. Click the Settings button to change the standard behavior of the screen saver you selected. (Each screen saver has its own settings dialog box.) Then, click OK.
7. In the Wait box, type the number of minutes the computer should wait to start the screen saver after you last touched the keyboard or mouse.
8. If you are the only person who uses your computer and you are not concerned about security, clear the On resume, display Welcome screen check box. Otherwise, leave this check box selected. Note: If your computer is joined to an Active Directory, the Fast Users Switching feature will be disabled. This is a common change made to computers used for business, and it happens automatically when a computer joins an Active Directory domain. However, disabling the Fast User Switching feature is not the default setting. Almost all computers in home environments will have Fast User Switching enabled. When Fast User Switching is enabled, you'll see the On resume, display Welcome screen check box. If you're part of a domain, you'll see the On resume, password protect check box.
9. Click OK.
Jan 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Canon Pixma MP140 freezes, only alarm lamp is on, no code error
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • Jan 01, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    Ink absorber is full canon MP145
    Hi this works with some MP printer gave it a go.
    First you must Turn off the printer
    1. Hold the Resume Button (red circle in the triangle), add a printer (click "Power") an indicator light green.
    2. Hold the Power Button, release the Resume Button.
    3. Not releasing the Power Button, double click "Resume" and release Both Buttons.
    4. Click "Resume" for Four times
    5. Once you click "Power", to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
    Dec 14, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    Away from computer, screen goes black. cannot resume. have to turn off (reset) computer
    It must have gone into sleep mode, Close your laptop screen and open it again, if it doesn't work get professional help
    Nov 10, 2008 | Toshiba Satellite 1105 Series 14.1" Flat...
    Printer not working properly
    The DeskJet printers are notorious for this problem. When you turn the printer off and back on in the middle of a print job, it gets confused when it is back on and cannot interpret the print language when it resumes from the computer. Whenever this happens in the future, you need to delete the print job off your pc before turning the printer back on. If you have windows XP, click START, SETTINGS, PRINTERS&FAXES, then double-click on your printer icon. When the queue window comes up, right-click on the active print job, select DELETE, then reply YES to confirm. If you don't see the print job delete (it might take a minute or so), then you will have to stop/start your Windows print spooler. Go to START, SETTINGS, CONTROL PANEL. Double-click the ADMINISTRATIVE TOOLS icon. Double-click the SERVICES icon. Scroll down and locate PRINT SPOOLER. Right-click on it and select STOP. Wait about 10 seconds, then right-click on it again and select START. Close out of the SERVICES & CONTROL PANEL windows. Open your printer status window again and see if it is clear. Once it is clear, it will be safe to turn your printer back on. Hope this helps.
    Mar 05, 2007 | HP DeskJet 648c InkJet Printer
    Black & Decker Mouse Sander/Polisher  Logo
    413 people viewed this question
    Top Black & Decker Tools & Hardware - Others Experts
    Jim Goldsmith
    Jim Goldsmith
    Rabbit Brains
    Rabbit Brains
    Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
