Question about Sony Cyber-Shot DSC-T5 Digital Camera
My canera is saying insert the memory stick - Sony Cyber-Shot DSC-T5 Digital Camera
My sony camera is vibrating
Posted on Jan 18, 2011
    Problem Solver:
  • 10 Answers
Do you have a memory stick storage device? These cameras have a small internal memory built in. But to take more photos once its full this memory storage device is needed. There a several models with different sizes. Also, look into the owners manual and learn how to adjust the size of the photo. The larger the size, or input, the less total number of photos you can store. Large size photos are intended to print at a higher quality or larger size which you many not need. Search the Internet for Sony Memory Sticks or go to a local photo store (call first and ask if they carry Sony products). Good luck.
Posted on Oct 10, 2010
When i go on my psp i wuz puttin a game on it then i turned off my psp then it goes nd says memorycard can not be read then i keep trying to format then it say after it done that it says no memory cad...
  • 1 Insert the problematic 4GB Memory Stick Pro Duo into your PSP and turn the system on.
  • 2 Select "Settings" from the cross media bar and scroll down to "System Settings." Press "X" to access the sub menu and select "Format Memory Stick."
  • 3 Press "X" to confirm the formatting of the stick. Your PSP will delete any content on the stick and reformat to match how the PSP stores data and organizes files.
Jun 04, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
Hi, I have a Kodak EasyShere canera, model # Z712 IS. I used to be able to take hundreds of pictures before the memory was full on this camera. Now it says it's full after 14! How do I correct this...
Somehow, you started using the camera's internal memory which is very small. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work properly.
Mar 23, 2011 | Kodak EasyShare Z712 Digital Camera
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
Hi I have a sony cyber shot camera when i tried to ON it The memory stick error appears saying " INSERT MEMERY STICK" inspite of memery stick is inserted also i get this error.And when i tried to format it...
The Reinsert Memory Stick error message appears when the inserted Memory Stick is corrupted or not in a correct Format. This issue can be resolved by trying the steps mentioned below:
  • Remove and re-insert the Memory Stick in the Camera.
  • Check if the inserted Memory Stick is compatible with the Camera.
  • Format the Memory Stick in the Camera. Do not Format the Memory Stick in the Computer, as this will damage the Memory Stick being used in the Camera. The Camera will not detect the Memory Stick again, if it is formatted in the Camera.
  • Clean the terminals of the Memory Stick by using a soft dry cloth.
  • Remove the Memory Stick from the Camera and check if the Internal Memory is working fine.
You may also try power resetting the Camera. Power resetting can be done by removing the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cameras
Reinsert memory stick --- I have removed battery and memory stick with no result. Help
Sony says:
Article ID : 101488 (modified 10/29/2009 03:18:00) Question: A warning message appears on the LCD screen when a Memory Stick is inserted into the camera. Answer: The following could be possible causes for the error message to appear:
  1. Verify that the Memory Stick is inserted correctly.
  2. The inserted Memory Stick cannot be used in the camera. Refer to the related link below for compatible Memory Stick.
  3. The Memory Stick is damaged.
  4. The terminal section of the Memory Stick is dirty.
http://www.sony.com.ph/support/faq/101488/product/dsc-w190/modelfirst
Jan 02, 2010 | Sony Cyber-shot DSC-W180 Digital Camera
My phone is not detecting the memory stick micro
Format the memory card in pc or any other phone then insert in your phone it will work.
Aug 11, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Memory stick pro duo installation
All labels to face user. Etched out corner is always bottom left. Best to have good grip on the adapter before inserting duo card.
Feb 22, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory stick cannot be detected
STICK LIGHT COMES ON AND STAYS ON COMPUTER SAID ITS DEFECETED. I had just used it
Jul 08, 2008 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
"Memory Stick not inserted" msg even though it is!!!
first of all
clean the pcb board with accitone
if it not works please change memory card ic
Dec 11, 2007 | Sony Ericsson Z550i Cellular Phone
Sony Cyber-Shot DSC-T5 Digital Camera Logo
42 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
