Question about Garden
Mculloch m7053d front wheel where to get replacement
Where can we find an ignition coil or what is a current part number for this part. It is a CTM-32-EM Mculloch String Trimmer
the part will be available from any mower shop or mccullock dealer spares
try e-bay as well
Mar 28, 2016 | Garden
Need to know carb mixture
fuel mixture for 2 stroke' s is 20:1
100ml of oil in 5L of fuel
Mar 13, 2015 | Oregon McCulloch 12" Chain Saw Repl. Chain...
I have a mculloch trim mac sl+ but it will only run on 3/4 choke, any ideas?
It can be a dirty carb, plugged filter or a bad fuel line.
Aug 31, 2013 | McCulloch Garden
Front wheel assembly diagram
For front wheel assembly diagram and replacement,click the link below and go through procedure:----Front wheel hub assembly Diagram and replacing procedure? http://howtobyme.blogspot.in/2012/02/front-wheel-hub-assembly-diagram-and.html
----------Front wheel assembly diagram to replace wheel bearing? http://howtobyme.blogspot.in/2012/02/front-wheel-assembly-diagram-to-replace.html
-------------How to replace Front wheel bearing? http://howtobyme.blogspot.in/2012/02/how-to-replace-front-wheel-bearing.html
-----------Check all 3 links one by one.This will help.Thanks.
Feb 22, 2012 | Ford F-250 Cars & Trucks
How do i fit a drive gear on to a mculloch gladiator 550 as i have bought the new part and dont know how to fit it
If you are talking about the main small drive gear that drives the larger crown wheel, then you need to remove the four screws holding the gearbob assembly onto the engine, the drive gear is screwed thriugh the bearing and into the drum, they are usually very tight, so you need to clamp the damaged drive gear with a suitable pair of grips and turn the drum to unscrew it, it should be a normal right hand thread.
Jun 08, 2011 | Garden
My Mculloch 610 wont start when hot
When it won't start, remove the spark plug and test for spark--it should be blue and snappy. If weak or nothing, try a new plug. If still nothing, the ignition module may be failing from engine heat. Before replacing same, check the module gap to the flywheel magnets with a thin business card. If it seems excessive, insert the card into the gap, loosen the mounting screws and allow the module poles to contact the magnets, then re-tighten the screws. Rotate the wheel to remove the gauge, then rotate it one full turn to make sure the gap doesn't close up. Recheck for spark. If the module dies from the heat, replace it. Hope this helps!
May 22, 2010 | Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
