Question about Cameras
Camera problem, shows "Acsess"...
My camera will turn on, but then it just shows access and the lens will go out as if it turns on, but then closes as if it is shutting off, then it will do that 3 more times, then it says turn off then turn on again, so I do that, but it does the same exact thing. What is wrong with it?
  • Cameras Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 31, 2008
Turning on the camera.
You can try to remove the battery to allow the circuitry to reset to factory defaults. If that do not work, I would suggest to get repair under manufacturers warranty. Most electronics devices have one year warranty.
Good Luck.
May 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
My camera turns on by itself even with the slide in front in the closed position. The screen then shows the warning that the lens cover is closed. When I open and reclose the lens cover in 10 or so...
Most likely some dirt, dust, or other particle is jamming the lens opening gears. You can try to spray some compressed air into the lens assembly, hopefully dislodging whatever is obstructing the lens cover. If this doesn't work, the camera will have to be serviced, which can be expensive. If the compressed air doesn't work, and you decide to have it fixed, get an estimate first. Often the cost of repair justifies going ahead and purchasing another camera.
Good luck, thanks for using FixYa, and hope this helps!
Aug 05, 2010 | Sony Cyber-shot DSC-T77 Digital Camera
Lens cover would not close. Now camera will not turn on.
Lens cover not close, This will happens due to two reasons.
1) Either your camera battery got died or need to be recharged or replace. or 2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Rating the solution is highly appricaited...Good Luck.
Mar 03, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
MY CAMERA LENS OPEN CLOSE E READY ACSESS NO
so i charged my battery, and same thing happends. Bought a new battery, didnt chatge it fully, but had one charge bar on it and the same thing is going on??????? ANy suggestions
Jan 14, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
When turn camera on lens opens and close
there is a friction in the movement of the lense assembly. It is not reaching to its proper position. This happens if you drop the camera, or the camera is exposed to sand. a repair technician can fix it.
Mar 21, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Lens error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Jan 03, 2009 | Cameras
Camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Mar 29, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Problem*cybershot DSC-S40
You have a jammed lens error the lens has to be repaired or replaced. You dont have to drop the camera for this to occur it can happen when ever the camera is in your pocket or purse. it accidently gets turned on and when the lens is coming out it is obstructed and strips the little plactic gears in the lens.
Feb 19, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
I think my camera's stuck
I had the same problem the lens wouldn't retract and it would only stay on long enough for the logo to show...I found out my lens changed slightly cooked to oneside I gently moved the lens to center and now it works great...look at the lens and see if this helps
May 16, 2007 | Pentax Optio M10 Digital Camera
Cameras Logo
110 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
