I have an ASUS GS2, when powered up the screen will randomly come on, it usually remains black? I am fairly knowledgable with computers and would like to try and fix it since I do not know if it is worth taking it into a repair shop. Any suggestions as to what the problem is or where I would begin troubleshooting the problem. Is is worth the money to have it reparied if it is not something I can do??
  • 11,800 Answers
Simple test to determine if the problem is hard or soft: try to boot into the BIOS. If you can then the problem is soft - just a reinstall will fix that.
If you can't then it's hard and now you must determine if the problem is in the connections to the LCD panel or the backlighting: light the screen with a powerful flashlight - if you can see the normal image then the backlighting has failed - you must dismantle the screen and find out why, most likely the connections inside the panel are loose . In that case to fix it you must dismantle the LCD screen and reseat (or resolder) the wires.
If you can't see the image then the connecting wires that go thru the hinge are loose - reseat or replace them.
Yes, it's worth the money (a connecting wire loom will cost you less than $50), yes, you can do it yourself - all you need is a screwdriver and some time to do the job properly, without rushing.
Posted on Oct 10, 2010
I have a Philips Ambilight 47PFL7603D/10, during use the screen will randomly turn off/go black, but the sound remains as normal. If I turn the TV off and on again the TV will work again for 5-10mins.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
ayo
Aug 02, 2015 | Philips Televison & Video
My asus laptop k51ac does not start. the screen remains black, though at times it starts up after several on and off.all lights are on.
Try removing hdd and RAM. See if it comes on reliably. If it does, then replace the RAM and try again. If OK replace the hdd and try again. If it fails at any point, there is the problem if it is now OK, it was probably a dirty connector that has been cleaned by the action of removing and replacing.
Sep 14, 2014 | Computers & Internet
Intermittent dropout on monitor screen
Check Monitor cable maybe even replace if not check graphics card and check monitor on another computer if problem still happens on second computer you screen has had it
Apr 17, 2014 | ASUS LCD Monitor
Screen remains black when coming out of sleep mode asus a8n-vm cms motherboard
IT is most probably windows 7 issue. I saw problem with desktop computers coming back from sleep for many times.
I advice you to avoid sleep. If that is not issue, first test memory, cause sleep stores everything to the memory.
Please tell which OS you use ? As said on start it might be Windows 7 ...
Oct 10, 2013 | ASUS Computers & Internet
Start up
First I will suggest you to Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen
After that restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacture site of your laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing black screen
Jul 04, 2013 | HP Pavilion DV2910US Laptop
Hello I have a ASUS Eee PC 1005. How do you know if your video card is blown? I have some knowledge of computers but not this brand. I turn it on and 2 blue lights come on (the light bulb and wifi) but...
This is more likely to be the Inverter which provides the power to illuminate the screen. I have just had to replace mine in a Toshiba laptop. Having said that, mine would power another monitor. The cost is about $90.The video card is usually part of the motherboard. The website tells you everything apart from the video! http://usa.asus.com/product.aspx?P_ID=BtksJTDENqfsnuyf
If you have two computers with the same problem, I would contact Asus for warranty repair, as having two fail is too much of a coincidence.
Apr 11, 2011 | ASUS Eee 4G Notebook
Acer Aspire 5100 laptop's screen remains black at start-up
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
Sep 19, 2009 | Acer Aspire 5100 Notebook
Random Blank screen at startup. All lights runed on.
shut it down properly from the command line or/and keep power button pressed for 5 sec's or so
Jun 23, 2009 | ASUS Eee PC 901 XP Notebook
My screen randomly blacks out.
the best method to overcome this problem is format the computer!!! i too used to get the same problem!!i did format it...!
Dec 30, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
