Question about Advent Netbook
I noticed a problem on my netbook which turns out to be a virus - Security Tool. I was unable to go into the Task Manager and was also unable to use the Run command from the start menu. I decided to reboot and try running in safe mode. I was unable to do this and now I get Windows Boot Manager saying Windows failed to start. A recent hardware or software change might be the cause. To fix the problem: then I am told to insert the installation disc but I did not get one when I bought the netbook nor do I have a cd disc drive. At the bottom, it says File: \Boot\BCD, Status: 0xc0000034, Info: An error occurred while attempting to read the boot configuration data. If I press enter to continue the sreen goes back to this same message. If I press escape to exit, it also does the same. I am using Windows XP. What do I need to do? Thanks in advance
Security Tool likes to download instantly. My last encounter wiped me out for months even though I had bitdefender (anti-proactive virus protection) of course the jerks were absolutely no help and kept asking me to perform insanely difficult and meaningless GMER files and all sorts of other stuff that had no baring on my situation. I was able to access task manager, stopped the program from running, hunted the program and virus attachments and removed them one by one many of which I found automatically starting in the registry. My final step to fixing my problem which even after a month of asking bitdefender the answer to no avail, was to run winsock utility, which fixed the issue with me not being able to log on to the internet. But, that did take care of my problems, except for a few remaining virus definitions I had originally missed needed to be eradicated.
In your case however, it sounds like you have lost a very crucial portion of the operating system. Hence, the request for the illusive back-up CD, nobody ever actually gets.
They found out that if they don't give us our operating system on CD-Rom any longer that we will be at their agonizing mercy on the end of a once great technical support system degraded into last ditch attempts to steal your time and patience, before driving you up a wall to the roof with a shotgun, by companies with philosophies like, "well, you're the one who bought it." "How is it my fault that I sold you this piece of junk." because they know if you go somewhere else you're bound to eventually have an even crappier experience with one of their subsidiary companies.
Posted on Oct 14, 2010
Unable to locate component Explorer EXE
Oh dear, Explorer.exe is the front end.
This is the user shell, which we see as the familiar taskbar, desktop, and other user interface features. This process isn't as vital to the running of Windows as you might expect, and can be stopped (and restarted) from Task Manager, usually with no negative side effects on other applications. space.gif
Note: The explorer.exe file is located in the folder C:\Windows. In other cases, explorer.exe is a virus, spyware, trojan or worm! Check this with Security Task Manager.
Nov 28, 2013 | Acer Aspire One PC Notebook
Tip
Enable the Registry Editor, Task Manager and Folder Options Disabled by Viru
Virus attack is common these days and we often come across the problems like Disabled Folder Options or like Task Manager and Regedit disabled by Administrator. These problems are nothing but virus activities. The virus has infected our system and stopping us from accessing these options.
Pressing keys Ctrl+Alt+Del opens up a dialog saying that “Task Manager has been disabled by your Administrator” whereas you are the Administrator yourself. It becomes very annoying when you think that you can fix this problem by going into the Registry Editor but it doesn’t show up. Even the Folder Options gets disabled.
This problem is generally caused by a virus named “Brontok” but don’t worry just use RRT (Remove Restrictions Tool) that can easily solve this problem. RRT is free and can successfully enable:
1. Folder Options
2. Regedit (Registry Editor)
3. Task Manager
4. Show Hidden Files option
The tool will come more useful if you use it in Safe Mode.
Download RRT
on Nov 17, 2008 | Microsoft Windows XP Professional With...
Hey the problem is my emachines netbook is keep turning off it self
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
http://onecare.live.com/site/en-us/default.htm
http://www.eset.com/us/online-scanner
http://www.pandasecurity.com/homeusers/solutions/activescan/
An excellent free utility for overall system maintenance is Advanced System Care Free ( http://download.cnet.com/advanced-systemcare-free/3000-2086_4-10407614 .html ). I use this utility on a regular basis.
You should always run anti-virus software. There are several very good, free, anti-virus products available. One good source to read editor and user reviews, and safely download anti-virus software, is http://download.cnet.com -- search for free antivirus software. In addition to the reviews, you can see how many people are downloading the software, which is another good indicator of how popular it is.
I have used AVG Free ( http://download.cnet.com/avg-anti-virus-free/3000-2239_4-10320142.html ) , and Avast Free ( http://download.cnet.com/avast-free-antivirus/3000-2239_4-10019223.htm l ). Both are very good, and completely free. At present I am using Avast on all of my home computers.
I have heard good things about Avira AntiVir Free ( http://download.cnet.com/Avira-AntiVir-Personal-Free-Antivirus/3000-22 39_4-10322935.html ), and it has good ratings, but I have not personally tried it.
In addition to Avast or one of the other free anti-virus software packages, I also run Ad-Aware ( http://download.cnet.com/ad-aware-free-internet/3000-8022_4-10045910.h tml ). Ad-Aware is a free anti-malware, anti-spyware package.
Dec 09, 2011 | Acer eMachines 350-2074 Netbook
How do I turn task manager ON?
Hi, It can be due to virus issue. Kindly have an Anti-Virus installed and then try.
Jul 15, 2010 | Microsoft Windows XP Professional SP2
My Nieghbor loaded at least 3 rogue anti-virus programs onto her Acer. The netbook has 2 legitimate users. Most control panel, security center and other critical applications have been blocked from use...
sounds like spyware still got thru even with all the anti-virus programs running. Best thing to do is to save all the important data onto an external drive or flash drive and then reformat the drive and reinstall the drivers for the hardware and put the applications that you want back onto the computer. This time only install one anti-virus program onto the computer.
Apr 28, 2010 | Acer Aspire One Netbook 8.9" Notebook
How can i now i have virus on my laotop
by scan you laptop with a virus software
Aug 14, 2009 | Computers & Internet
Task manager disabled by the administrator
To regain access to your Task Manager and Folder Options, the quickest remedy for the moment would be to download and run RRT.exe. It is "Remove Restriction Tool" and available here.
For Anti-Virus, you can try AntiVir by Avira available here. Additionally, you may want to download and install Lavasoft's Ad-Aware here. Upon download, install and update. Thereafter run a full scan. Pls follow on screen instructions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 27, 2008 | Microsoft Windows XP Professional
Task manager
If you are certain that you are logged on as administrator or has administrator privileges, then a virus is preventing your opening of the Task Manager. Additionally, the same virus is likewise preventing access to the Folder Option and the MSCONFIG function.
Of course the correct solution would be to run a full deep virus scan and delete detected ones. You can also try running RRT.exe to force access to the above functions.
Mar 29, 2008 | Microsoft Windows XP Professional
Advent Netbook Logo
100 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
