Question about Hotpoint Aquarius WF000 Front Load Washer
WMA31 I have a Hotpoint Aquarius WMA31 and it will not spin, can you tell me what the problem is and how I can get it fixed
If the drum turns but will not go into spin you could have a wire broken leading to the motor plug.If it does not move at all it could be the brushes worn down or a wiring fault. You would have to check along the length of the wire from the control module to the motor (the best way to test for a broken wire is with a multi meter), unplug the motor plug and cut the cable ties so you can bring it up to the front of the machine next to the module, then you can test each connection in turn by putting one of the meter probes in each of the motor plug terminals while placing the other probe in the module plug. Hope this made sense.
Posted on Jun 05, 2008
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum) Of course you can direct the hose into sink, fine. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your problem will be back for someone else to solve.
Posted on May 31, 2008
My hotpoint aquarius wma31 washing machine won't drain any suggestions???
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Sep 17, 2010 | Washing Machines
My Hotpoint WMA31 will not drain - the smell is
check for blockage under cap bottom of washing machine
May 26, 2010 | Hotpoint WMA31 Front Load Washer
Door lock flashes doesnt work or start up
The flashing door lock light is indicating that the door is not closed proerly.
This can be caused by a weak or broken spring in the door handle.
Another reason for this to happen, is a faulty control board at the top of the washer, a blown track will cause this.
This in turn, is usally caused by a fault on the motor.
Hope this helps.
Jan 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint aquarius WMA31 washing machine, conditioner is not leaving the draw, pleas help
Could be dirty drawer ,clean out fully..or faulty solonoid valve ..Replace..cod supply has 2 valves 1 for rinse 1 for softner....Hope this helps
Oct 08, 2009 | Washing Machines
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA31 Washing machine will not spin
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Aug 25, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius 1100 spin WMA31
I have just had the same problem too, i fixed it by reattaching the belt and making sure that the belt at the motor was flush with the edge of the motor spindle, right at the end, it looks dodgy, but it works
May 29, 2008 | Hotpoint Washing Machines
Dont understand what the programs do
my hotpoint aquarius wf540 lights keep flashing
Mar 01, 2008 | Hotpoint WMA31 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
175 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
