Question about Apple iPod touch
I forgot my ipod touch passcode i have tried everything! What Do I Do!!!
  • Apple Master
  • 7,482 Answers
Try this...
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
For this FREE answer, Please rate me
Posted on Oct 10, 2010
Forgot id and password
If you forgot the passcode for your iPhone, iPad, or iPod touch, or your device is disabled Follow these steps if you've forgotten your passcode, or if a message says that your device is disabled.
Forgot passcode for your iPhone iPad or iPod touch or your device is...
Sep 21, 2015 | Apple iPad Mini
How to unlock an ipod
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Mar 04, 2013 | Apple iPod touch
Forgot passcode for apple touch ipod
If you forgot your passcode then you need to restore your iPod touch. To do this:Connect device to your computer that you sync everything within iTunes go to the device and on the front there should be restore your iPodClicking on this will allow you to access your iPod touchNOTE: you MAY lose your data by doing this.You have been warned.
Dec 29, 2011 | Audio Players & Recorders
I forgot my passcode for ipod touch,how do break passcode with different computer with out losing any music saved in it
*THIS IS THE ONLY WORKING METHOD*
What most likely has happened is that you or someone was trying to access your iPod and tried to enter a passcode to get in. After a certain amount of tries, your iPod will disable itself. Here's how you can get it back.
Step 1: Turn on your computer, and connect your iPod to your computer with the USB cable that came with your iPod.
Step 2: Open up iTunes on your computer.
Step 3: In iTunes, go to the left side of your screen and scroll down, when you see your iPod, select it.
Step 4: You should now see on the right side of your screen some general iPod information. Scroll down to until you see a "Restore" button.
Step 5: Hit Restore, and wait for a few minutes. THIS WILL WIPE EVERYTHING THAT WAS IN YOUR IPOD AND RESYNC IT WITH EVERYTHING THAT IS IN YOUR ITUNES LIBRARY.
Feb 10, 2011 | Apple iPod touch
I forgot my passcode and my ipod is disabled i hooked it up to itunes and it keeps saying that i have to type in my passcode to use it
Perform a restore via iTunes. That will reset everything. Then resync to get your music back onto the iPod.
Jul 12, 2010 | Apple iPod touch
Forgot passcode and wont unlock how do I unlock it?
Try to remember your passcode because the solution that I'm going to recommend to you will wipe out all the data from your iPod touch.
If you totaly forgot, the only thing you can do is to put your iPod touch to DFU mode and then restore.
Click here for step by step instruction on how to do that.
For more iPod touch / iPhone tips, click here.
Feb 06, 2010 | Apple iPod touch
Forgot ipod passcode
simply plug your ipod into itunes to unlock the code
Jul 23, 2009 | Apple iPod touch Second Gen (8 GB,...
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
