Question about Admiral 24 in. DDB1501AWW Free-Standing Dishwasher
I Have 3 problems with my dishwasher, my dishes are always coming out with food and grit. I've tried numerous soaps and powders, the motor makes a very loud loud every time it's used. and the latch works but I can opent the door mid cycle it doesn't stop water sprays everywhere
  • mukie666 Oct 13, 2010
    thank you the solution has helped I think the motor is the wash cycle being that it makes noise at the beginning of the wash.. It was all helpful
  • Admiral Master
  • 3,247 Answers
Regarding the problem about dishes coming with food and grit - it is possible the wash water is getting contaminated with stuff that should normally be sucked out by the drain pump up in the dishwasher. This is linked to the accumulator and chopper part of the wash system. The food particles are collecting in the accumulator and mixing with the wash water. Normally the chopper should expel it out through the drain wash system. You will have to disassemble the accumulator and check what is wrong. See the diagram - parts 7 and 8,
Now regarding the motor noise - this model has 2 motors - one for wash and one for drain. Which motor is noisy will depend on whether this comes during the wash cycle or the drain cycle. Usually it is the bearing that is faulty. You can replace the motor by checking the previous diagram.
Regarding the door switch - I am not clear what the problem is. Unless you pause the cycle on the panel I would not open the door. The unit works with 2 door switches - both must be closed (when you shut the dishwasher) in order for the dishwasher to complete full cycle. It is possible one of the switches is always on and this controls the wash system. Check the door latch operation and the location of the 2 switches in this diagram.
Hope this will help you determine the problem and replace the parts. Please rate this solution if you found it usefuly.
Posted on Oct 10, 2010
My Samsung model #WA4H7000AW/A2 seems to always need an additional rinse to get rid of soap left behind. Is this a common complaint ?
Here are some questions that may help.
1) Is the water hot enough? Since the soap "melts" better at higher temperatures, cooler water can leave a soap film.
2) Are the dishes clean before you run the machine? We like to used the dishwasher to "sanitize" the dishes, so we rinse them really good before washing them, to get off caked food residue.
3) Try changing washer soap, try powder if you used liquid, or visa-versa, and try less quantity and see if any of those help.
God bless your efforts.
Dec 19, 2016 | Samsung Washing Machines
My dishwasher model FFD612EMBGS keeping half of the detergent in its location it dose not take it fully and some detergent powder snag on the dishs
Check to make sure you are not blocking the soap dispenser door with a large platter or pan in front of it. The water will not be able to wash out of it.....
Jan 29, 2014 | Frigidaire FFD612EMBGS DISHWASHERS FOR...
Grit in clean glasses and on dishes
Mary do you have a water softener? If so, only use 1 tablespoon of dry dishwashing detergent per wash. Don't use tablets or liquid soaps. Too much soap will wear down the items you wash, leave streaks and pock your dishes. That might be what the sandy grit is. Also, to get rid of the grit inside of your washer you can buy a special dishwasher cleaner at almost any hardware store. Always try to use a rinse-aid. Make sure your drain filters are clean. Hope this helps. Jewels
Mar 15, 2013 | Dishwashers
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
Does the two drawer use liquid or powder soap? Kitchen Aid Dishwasher is not washing things clean, there is a coating of dirty food particles on the dishes. Help!
About the soap: You can use both. I prefer tablets.
About the particles: Before putting the dishes in, remove the food with a brush ($2.00) in the sink and run the hot water from the faucet for a 1-2 min until it gets really hot.
Sep 30, 2009 | KitchenAid Dishwashers
After cycle, there is grit on my dishes
they are in your water valve very hard to get to have you switched to liquid soap much better
Apr 17, 2009 | Dishwashers
Top arm is not moving
Filter and rotor jets prob clogged.
In wash, the water is heated, supposed to dissolve the soap and then sucked thru a filter and pumped up the back and out the top to spray water everywhere.
Soap doesn't always fully dissolve and clogs the filter and some slimy gets thru and clogs the rotor jets.
To fix:
1. Remove Upper and lower dish drawers
2. Take off the Upper. Middle and lotwe rotors and clean their jets out with toothpick and frequent flushing (Plug a clean hole with toothpick to make water come out elsewhere) Use the sink on full blast to see if water comes out all holes.
3. Reassemble rotors.
4. Remove and clean filter. The filter is in the bottom above the Motor/pump and held in with 8 shiny hex-head or Torx screws. Take out all screws, lift out filter and clean in sink with warm or hot water from backside. Use garden hose for hard to reach areas.
5. Reinstall filter. Don't overtighten or you will crack it
6. Replace drawers
Done!
Mar 26, 2009 | Dishwashers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Soap hardens in the dispenser and dishes don't come clean
Either your dishwasher is not getting the water hot enough to dissolve the powder, or you need to switch brands. Try a liquid/gel type of dishwasher detergent.
Try stopping the washer a few minutes after you start a wash cycle. Open the door -- if there is a lot of steam coming out at you, it's not the water temperature. If there is no steam, your dishwasher is not getting hot water and/or the heating coil is not working.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Admiral 24 in. DDB1501AWW Free-Standing Dishwasher Logo
291 people viewed this question
Top Admiral Dishwashers Experts
Paul Bade
Mike Carew
richie46
Are you an Admiral Dishwasher Expert? Answer questions, earn points and help others
