Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Power light flashing...TV won't turn on
Suddenly, my TV won't power on. Instead, the (red) power button flashes twice, pauses, flashes twice, etc, etc.
There has to be a way to "re-set" it somehow, without having to call a tech in for a service call.
I have a Panasonic Viera HDTV 720P...Model # TC-32LX60. I've tried unplugging the TV and starting over, but no change.
Any advice or tips would be greatly appreciated.
Todd
  • 10 more comments
  • toddwilliam May 31, 2008
    I just fixed it!!! :)
    Seems to have been a power source issue.
    Not sure how to remove this post.
    It was a power supply issue, but i was able to re-set it myself by simply disconnecting the power source and kind of "re-booting" the whole thing.
    Thanks for the reply.
  • Anonymous Feb 10, 2009
    I thought it was a power supply issue to, but the cable box is functioning correctly, it is just the TV. I have tried unplugging the sets, the issue persists. HELP.
  • Travcoe Feb 14, 2009
    i had the same problem on a 2 month old tv, panasonic coveres a tech to come in and fix it right in your house if its 42"or over
  • e_little56 Feb 19, 2009
    I am having the same problem with a 50 in. The light flashes ten times then pauses.... HELP.
  • Anonymous Feb 24, 2009
    i have the 37 inch flm-373b, and the blue light stays on no matter what you do. if i unplug it,then plug it back in, the red light is back on and then i hit the power button and the blue light comes on, but still nothing. the lights do not flash at all
  • larry flinn Aug 06, 2013
    I have the same problem, how do I locate a good service center for a fujitsu plasma?
  • Anonymous Mar 15, 2014
    my panasonic #tc-p50x5 tv won t start if I unplug it or if there s a hydro flash . last tim,e this happened it took 3 days andf it started again and it s only been 1 day and hockey game is tonight
    if I unplug or if there s a power flash my tv won t start for 3 days and it s only been 1 day and hockey game is tonight model # tc-p50x5
    my 55 inch tv won t start if I unplug it or if there s a power flash I tried replacing the popower cord nothing slapped it the old fashion way nothing .... it s a panasonic viera #tc-p50x5 serial # lf20830287 thanx in advance
  • Anonymous Mar 31, 2014
    power supply replace
    Problem Solver:
  • 18 Answers
Two flashes sugests that the power supply is faulty.It will have to be taken in to a service centre for repairs.
Posted on May 31, 2008
Unable to set up remote URC 22935
MENU • Set Up • Searching For Yor Code • Blinking Back the Code:
Redefining a Key • Punch Through • Volume Default • Clearing Out
Key mover • Favorite Channel Scan • Macro-Sequence
How to Program your One For All remote
(Models URC-2005, URC-2099, URC-4005, URC-4050, URC-6050)
Set Up
After getting the proper codes from your manual or Customer Service, use the following instructions to enter them into your remote.
PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
PRESS and HOLD the MAGIC button until the red LED flashes twice, then RELEASE.
ENTER the 3 digit code for your brand.
You should receive 2 quick flashes after entering your code.
PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
menu
If you have tried all of the set-up codes for your brand of eqipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following proceedure to search for your code.
ENTER 9-9-1 (two blinks on the remote)
ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
When your device turns OFF, PRESS the MAGIC button and RELEASE it to lock in the code for your device.
menu
PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
PRESS 9 - 9 - 0.
PRESS 1, carefully COUNT the number of blinks. (1st digit)
PRESS 2, carefully COUNT the number of blinks. (2nd digit)
PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
menu
Redefining a Key
PRESS 9 - 9 - 2.
PRESS the DEVICE,(TV,VCR,CABLE,etc.),key you want moved
PRESS the DEVICE key you want to replace.
Example: If you want the Aux key to be a TV key:
"MAGIC" (2 blinks) 9 - 9 - 2, TV (you want to move TV)
Then AUX (you want to replace AUX).
menu
Punch Through
This sets Volume to work for one device in all modes.
For example, the TV volume will work in the cable and VCR modes.
PRESS 9 - 9 - 3.
PRESS the device key you would like the volume to come from.
You will get two blinks on the remote.
NOTE: This only sets volume in the TV,VCR,CABLE, or SAT mode.
If you want to set the volume for a device to work just one or two other devices- refer to the instructions under "KEYMOVER-From one button to another"
menu
Volume Default
Use this to get the original volume to work on each device.
PRESS 9 - 9 - 3
PRESS the VOLUME+ key, you will get two blinks.
Now The volume is set for all original devices.
menu
Clearing Out
A Device Key
PRESS 9 - 9 - 2
PRESS the device button twice. - Two blinks.
Any Button On The Remote
PRESS the button you want to clear - RELEASE
PRESS 9 - 9 - 4
PRESS the button you want to clear twice. - Two blinks.
All Key movers,Macro's, and Defaults
PRESS 9 - 8 - 0 -- Two blinks.
Scrambled Keypad
Sometimes it seems that the keypad is "scrambled". Functions like channels, volume, or numbers are not where they should be.
If your remote seems to be acting this way, try the following proceedure:
ENTER 9-7-3 (two blinks) (for URC-2005, try 9-7-4)
Try the functions on the remote
If the keypad continues to act "scrambled", you may:
Be on the wrong code for your device.
A wrong code may only operate a few functions of your equipment or they may be operating inaccurately.
Have something more serious wrong with the remote.
In either case you will have to contact us for more information.
menu
Key mover
An Advanced Function To A Button
PRESS 9 - 9 - 4.
PRESS the "MAGIC" button and then the three digit extended function.
PRESS the button you wish to use for that function - Two Blinks.
From One Button to Another
PRESS 9 - 9 - 4.
PRESS the DEVICE and the FROM button
PRESS the DEVICE and the TO button
Two Blinks
EXAMPLE: To take the volume from a TV and put it in the VCR mode,
it would be: MAGIC - 9 - 9 - 4 -TV - VOL UP - VCR- VOL UP - two blinks.
You would have to do the same process for VOL DN and MUTE.
"Shifted" Key Mover
In order to stack a second function on a key; when pressing the button you want the function on in the sequence, instead hit MAGIC and then the button you want.
To use the function: TAP the MAGIC button and release, then TAP the key you chose.
FOR EXAMPLE:VCR-MAGIC(hold 2 blinks) 9-9-4 MAGIC 2-3-4 MAGIC PLAY
If you hit the PLAY button - the VCR will PLAY, if you hit MAGIC -PLAY it will bring up a display.
menu
PRESS 9 - 9 - 6
PRESS the channel to be stored, up to 3 digits
PRESS the ENTER button
REPEAT steps 4 & 5 up to ten channels
If you do not store ten channels, you have to hold "Magic" for four seconds to close Favorite Cannel programming.
NOTE: To stop scanning, press any other button on the remote control.
menu
Macro-Sequence
This will allow you do do several functions with just the touch of ONE key.
PRESS 9 - 9 - 5
PRESS the key you want the Macro to be on
PRESS the sequence of keys you want the remote to do
PRESS "MAGIC" and wait for two blinks - RELEASE.
When you hit the key you put the macro on it will automatically start the sequence.
IMPORTANT: The Macro key will be the macro in ALL MODES so it is best to pick a key you will not need for anything else in any other mode.
menu
All Material Copyright Universal Electronics Inc.
"One For All" copyright Universal Electronics Inc.
Any questions about the products should be directed to help(at)ueic.com
Apr 03, 2013 | Televison & Video
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
I forgot the code of my chunghop universal remote RM - 133 E my tv is JVC
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then do these procedures
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
3. ENTER 9-9-1 (two blinks on the remote)
4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
1. PRESS and HOLD the SETUP button until the red LED flashes twice.
2. PRESS 9 - 7 - 5, the red LED will flash twice.
3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
4. PRESS the button that will receive the learned function, the LED will flash rapidly.
5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through
6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
Feb 15, 2011 | RCA Universal Remote Control
I need the codes and procedure to program a one for all urc3220 to my Zeinth tv.
016,017,092,000,[COMBO--000,037] are the codes
for your Zenith TV. Follow these instructions
carefully. These are as close as i can get you
to getting you operations...the rest is up to
you. GOOD LUCK!
  1. PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
  3. ENTER the 3 digit code for your brand.
  4. You should receive 2 quick flashes after entering your code.
  5. PRESS the POWER button to test the code.
If you have tried all of the set-up codes for your brand of equipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
  1. PRESS the button for device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
  4. ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
  1. PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
  3. PRESS 9 - 9 - 0.
  4. PRESS 1, carefully COUNT the number of blinks. (1st digit)
  5. PRESS 2, carefully COUNT the number of blinks. (2nd digit)
  6. PRESS 3, carefully COUNT the number of blinks. (3rd digit)
Sep 04, 2009 | Televison & Video
I need codes for urc 3220 on a ge tv
GE
002 006 007 018 107 114 310 312 502 601 704 719 803 806 810 901 911
you. GOOD LUCK!
  3. PRESS 9 - 9 - 0.
Jun 24, 2009 | GE 27GT271 TV
Need codes for zenith tv
www.rockabilly.net/files/manuals/URC-3220.pdf
Jun 04, 2009 | One For All URC4220 Remote Control
My problem is that I have A URC-3220. An that I have A Dish Network BOX I would like to make it work? I Do need the set up Instructions &Codes,for A SHARP T.V. THANK YOU.
SHARP
002 013 014 111 502 509 712 812 813 913 918
you. GOOD LUCK!
  3. PRESS 9 - 9 - 0.
Mar 23, 2009 | One For All URC-4330 Remote Control
Need code for zenith on urc-3220
you. GOOD LUCK!
  3. PRESS 9 - 9 - 0.
Mar 03, 2009 | RCA Universal Remote Control
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
1,427 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
