Question about Black & Decker Husky 750w Power Inverter
My Black & Decker 750 watt interter powers up with both fans running and 1 light of 3 with a beep after pushing the power button. then fans turn off. 1 liht that lit stays on but there is no power coming from the inverter. I plugged in a small string of xmas lights that worked in the wall then plugged them into the inverter. Nothing. there in no reset type butten . what gives ?
sleepy_user
  • 140 Answers
SOURCE: I purchased a black and decker 100 watt power..cant register it!!
http://www.blackanddecker.com/MemberCenter/ is the new site. Enjoy!
Posted on Feb 20, 2009
  • 7 Answers
SOURCE: how do I replace the fuses in a 750 watt black and
look for a cover to maybe flip up or slide (most inverters fuses are coverd)
Posted on Jul 05, 2009
cmcduncand
  • 714 Answers
SOURCE: How do i tell when the inverter is charged?
Question does not seem to match this inverters capability.
INFO:
This Power Inverter converts vehicle’s 12-volt DC power into household 115-volt AC power. AC and USB outlets power and/or recharge personal electronics.
We have owned one of these Power inverters for over a year now and have run a great deal with it, from TV to drill press PC and any thing that was small and that could run from my car. Very nice product.
SET UP: Connect wires. ensure correct polarity, push button on top. Plug in 110 volt appliance.
Hope this tip was of some use.
R/
David
Posted on Feb 14, 2010
  • 5166 Answers
SOURCE: I just bought a power inverter for use with my pc.
There are two possibilites: the first is the over 400W power draw, the other is how you have the inverter connected. Do you have the inverter connected directly to the battery terminals (the clips) not the outlet plug (cigaretter lighter)? This is needed for any load over 80W and under 400W. (the inverter can handle a load demand over the 400W limit but only for short periods (800W).)
What is the load that your PC pulls (Is it a laptop or a desktop)? The laptop in my home has either a 65W or a 90W load (depending on the battery and the AC adapter we are using). Desktops take much more power (usually).
I hope this helps.
Posted on Jul 15, 2010
SOURCE: Cant find the fuse on a black and decker 400 watt power inverter
I've had this inverter for about two years now, bought it for a cross country road trip to power my laptop and a couple of other things. I've pretty much liked it. Yes, the fan is a little noisey, yes, you have to use the provided battery clips for heavy loads. But it powers my Dell Inspiron 8500 laptop just fine (and its an old powerhog).
Recently a I let a friend use it with his inflatable mattress air pump during a camping trip.
What I didn't know is his pump has insane wattage, and it fried/bricked the inverter instantly.
Agh! I thought it was a goner, but took the time to look inside the unit. (Which is a solid and sturdy metal case, not plastic as another reviewer indicated). I was thrilled to discover there were some internal fuses. And while the fuses are soldered to the circuit board, if you've done any soldering at all they really are a snap to replace.
If you remove the four screws that hold the end cover plate on the side with the fan. You can remove the end plate and have just about a half inch or so of clearance. The entire lower circuit board will then slide out with firm pressure about an inch and a half (don't try and go any further, components on the other side prevent it).
On the right side (positive/red terminal side), you will see two 25 amp mini-fuses that are directly soldered to the circuit board. If these are blown (you can see through the semi-transparent sides if they still connect), that is most likely your problem. They are easily available from most auto and big department stores (Walmart, Target, etc) in their automotive sections.
I used a 40 watt soldering iron (30 watt should work fine), and applied it to the bottom of the circuit board where the fuse legs poke out the bottom. Using a pair of pliers, I applied a firm steady pressure to the fuse, pulling up, while applying the soldering iron to each of the legs (alternately) of the fuse. The solder melted, and I was able to work the fuse out in a few seconds. I did this for both fuses.
The replacement fuses cost all of $2. I dipped the new fuse legs in flux, then put them in the place of the old fuses. Again I heated the circuit board solder from below, and pushed the new fuse in place. Repeat with the second fuse until it is in place. Flip the board over and add some more new solder until it is firmly in place. Put it back together, and you are back in business! And for a whole lot less than a new inverter.
I've got pics of this process if anyone would like them. Good luck, and happy inverting.
Posted on Sep 21, 2010
What's your problem?how many amps on a 1/2 horse sump pump
750 watts is pretty close to one HP. However, the pump will have a much higher current draw on start up which may be too high for the inverter. (The accurate number is 745.699872 Watts per Horsepower)
Discounting any losses, 750 watts from a 120 volt supply will draw 6.25 Amps. so 1/2 horsepower should draw 3.125 while running. Startup current may be much more. Check your pump for its current draw (should be printed on the pump) and check it against the inverter's limits. It may be that the inverter is too light for the pump.
Apr 28, 2012 | Black & Decker Husky 750w Power Inverter
Will a 750 inverter run a sump pump off of a deep cycle marine battery for a short period of time?
Looking at this, how many amps does the pump normally draw? Take this and multiply by 3 for start up current draw. Now, multiply that by 120 (volts) and this will give you the watts. Start up current is what will knock your inverter down. It won't kill the inverter but it will overload it on startup and turn off the unit. Since I do not know the size of your pump, this is my caution. You could always try it, the most that should happen is that the inverter will shut down.
Feb 05, 2011 | Black & Decker Husky 750w Power Inverter
I have a 750 watt Black and Decker inverter that will only start up when turned on but immediately goes to the caution light and does not charge anything. It worked for a short while, only a few minutes,...
or that your drawing too muc power, though 750W is a hefty supply. what are you plugging into it, is it grounded properly, do you have thick enought supply wires?
Jun 11, 2010 | Vector VEC043 750-Watt Power Supply
INFO:
R/
David
Feb 12, 2010 | Black & Decker Power Inverter PI400AB
Describe your Black &
I have a black and decker 100 watt power inverter. When the led turns red you are ethier overloading it or it overheated. to fix it unplug it and let it sit for 5 minutes. Plug it in. Plug in an item rated for 100 watts or less. Or try to charge somthing on the usb port.
Aug 23, 2009 | Black & Decker 100 Watt Plug-In Power To...
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Describe your Black & Decker Power To
No. You will need typically 35-40 watts for a LCD monitor. 20 watt may not even run DVD's on your laptop. Look for something 80 watt or so.
Jul 07, 2009 | Black & Decker Power To Go Cordless AC/USB...
How do I replace the fuses in a 750 watt black and decker power inverter
Jul 05, 2009 | Black & Decker 750w Power Inverter
Connection to car battery
The answer is yes...BUT make sure the polarity is correct and the inverter turned off when you make the connection
Apr 30, 2009 | Black & Decker 750w Power Inverter
Charging Black and Decker Simple Start
First plug the charge adapter into an outlet, then plug into the unit. Push the power button to turn the unit on. Now, push the button for the light. The light should come on. At this point you hit the charge button and the green light should start blinking and there will no beeping. Then turn off the light. The green light should continue to blink and the unit will charge. This worked for me, hope it helps!
Jan 19, 2009 | Black & Decker Simple Start Car to Car...
Black & Decker Husky 750w Power Inverter Logo
78 people viewed this question
Top Black & Decker Electronics - Others Experts
PNiss
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
