Question about Bunn NHB Coffee Maker
Coffee is hot but weak. - Bunn NHB Coffee Maker
    Problem Solver:
  • 10 Answers
This unit has a sprayer head that might be the problem. Start with the water. Filtered water is best after all, coffee is mostly water. As the water is heated to the optimum degrees it must spend the right amount of time going thru the grounds. The grounds have also an optimal size. We opted to have our own coffee grinder so we can select the right size for the righ taste for our needs. Now, do not go buy bottled water. That is WAY too expensive. Opt for a water filter. There are quite a few. If the water and the grounds are the right combo but still weak coffee call the customer service at Bunn and see what they have to say. Some customers have reported issues to them and a solution might be at hand, or a new sprayer might be needed. Good luck.
Posted on Oct 10, 2010
Saeco Vienna Deluxe -- Coffee weak weak weak
When the coffee is weak, that is often because the water is not at adequate temperature.
Check if the coffee is in right quantity and pressed in the right way. If it is than it means that the water was not hot enough.
Check water temperature, if water is completely cold, the element mus be replaced, if water is hot, but not enough, then replace thermostate activating the pump.
Oct 13, 2008 | Saeco Vienna De Luxe Espresso Machine
Coffee weak
warm up well before brewing coffee and set the grinder for finer coffee powder
Jan 19, 2016 | Gaggia Titanium Espresso Machine
My Vienna Digital suddenly makes weak coffee and it not hot
Try resetting the maching to factory settings.
Here is another question, bear with me, what do you brew the coffee into? And is it pre-warmed?
Jun 08, 2009 | Saeco Vienna Digital Coffee Maker,...
WEAK COFFEE & NOT HOT ENOUGH
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Dec 22, 2008 | Bunn NHB Coffee Maker
Won't perk properly
Oct 21, 2008 | West Bend 13500 Coffee Maker
The water that comes out thru the coffee gounds and into the carafe is only warm not hot.The coffee that is brewed is weak and only warm.
Sep 12, 2008 | Krups Small Appliances Espresso Machine
Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Jul 11, 2008 | Bloomfield 8571 Coffee Maker
Bunn NHB Coffee Maker Logo
162 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
