How do you put a bendix door handle and clip together model 71388 both supplied seperatly machine wont go on so I think must have not been put together correctly by me
  • Washing Mach... Master
  • 17,130 Answers
If the door does not lock well the safety door switch will not reset as the washer will not start any function.
So the door handle with the lock must be set right to click into the position.
To show how a handle can be replaced is difficult unless with a video demo.
Please cchecck this video link. Click here for door handle changing.
Click for door lock changing.
Though the above videos are not the models specified, the logic will be the same.
Please try and see with these info if these tips helps.
Posted on Oct 10, 2010
Tricity bendix user manual
I have never failed to find a manual online. Go to bendix web site and search model.
Aug 22, 2014 | Washing Machines
Door Clip Assembly
which is the model?
Mar 08, 2008 | Washing Machines
Hi my ford door wont open from the out side
This is a generic answer since you didn't say what year or model it is.
This requires removal of the door panel and PLEASE DO NOT USE A SCREWDIVER TO PRY THE PANEL LOOSE, you can get a cheap fastener release tool from an auto supply store. It looks like a carpet tack remover.
Inside the door there's a link that connects the outside door handle to the door latch. This link goes into a hole in the latch AND a hole in the door handle and is secured with clips. If one of these clips fall off, vibrations will eventually cause the link to fall out of these holes. Put the rod back into the hole and put a new fastener on it.
Jan 10, 2011 | Ford Fiesta Cars & Trucks
How do remove the cover to expose the belt on tricity bendix aw1100s it seems sealed no back pannel
Your remove the front or side panels. Look for any screws to remove first then there will be spring clips that you pry on the side or front where you see it's put together. The spring clamps will release. You need to post a model number to get more specific info.
Oct 18, 2009 | Tricity Bendix AW1000W Front Load Washer
Hotpoint Door handle will not return to latched position
the spring in the door handle assembly is broken,the spring is replaceable seperatly.
Aug 22, 2009 | Washing Machines
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Door wont open
Managed to pull back casing on door to reveal the handle and pin holding it together. Once i had pulled pin up slightly the door opened to reveal the door handle catch had broken. Engineer has fitted a new handle and everything is fine.
Jul 22, 2009 | Whirlpool LHW0050PQ Front Load Washer
Assembling a steam vac handle part
when the machine comes new the way it is installed is to put the upper handle on the lower handle, install the bolts & nuts (tighten) and then to pull the trigger and press the surge button (if this model has one). you will feel them snap together. the clips on the rods should be at 90 degree's from each other. one will be a u type channel and the other a v type and will connect.
Jan 07, 2009 | Hoover F5810 SteamVac Upright Vacuum
98 Jeep Wrangler door handle won't open door
there is a metal bar inside that clips into the handle they come off all the time there is a plastic clip that hold the 2 together it most likely has fallen off and into the bottom of the door you can put it back together easily if clip cannot be found you can buy them at local parts store for a couple bucks..hope this helps
Nov 21, 2008 | 1998 Jeep Wrangler
Door handle replacement
I tried different ways of putting the door handle and lock together. It took me 5 hours to eventually work it out. Now the problem is solved.
I took a digital photograph of the lock before I put it back onto the machine, so now I have a permanent record to refer to next time. I say next time, because we've had 2 Servis Washing Machines, and between the 2 machines, the door handle has broken 4 times, through no fault of ours, each time having waited for the time switch to deactivate.
I think by now the company ought to make the plastic piece that keeps snapping, out of aluminium.
Sep 12, 2008 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
