Computer wont start
My computer turns on for a second beeps like a siren high/low 2 times and then shuts itself off.
  • KELRYSHA May 31, 2008
    ok, I found out that the beeps mean it is a thermal warning through the intell sight, but they didn't tell me how to fix it. I have changed the power supply and for the few seconds that it does run all of the fans come on. I just think it needs to be reset somehow. The model of my computer is Systemax Venture HU2 B840 RTS PC, Intel Pentium D processor 840 3.2 GHz, MBO D945GPMLR VIIV MB
  • 30 Answers
The beep codes are related to hardware issue with your computer. Could be the RAM, video card or the motherboard. However to help you better, we would need to know the model number of your computer and preferrebly the BIOS manufacturer
Posted on May 31, 2008
Spins but makes a beeping sound and wont register.
Well, It sounds like there is something lodged in your Hardware drive...The beeping is probably a warning signal to tell you that it is not properly booting up...You should go to a Computer Repairman...
Jul 11, 2013 | Seagate FreeAgent GoFlex Desk 1TB USB 3.0...
Psu wont turn on
Test the PSU. Unplug it from the motherboard and then with nothing connected, short the green wire to any ground (usually a black) using a paperclip and it should come on and stay on if the problem was with the motherboard/computer but if it shuts down, then you know the problem is the PSU itself.
If the PSU stays on under no load, then one possibility is you had too much connected to it and it shut down as a protective feature. The Bios would not beep if the PSU is shutting itself down. Also make sure you have the internal speaker connected. It's possible you just can't hear the beep because there is no speaker connected or it may be connected to the wrong place.
Don't throw away a defective power supply. It is worth a couple bucks as parts for an electronics enthusiast. Keep it out of the landfill.
Jan 16, 2013 | RaidMax Computers & Internet
Hi I have a viper 5701 it was working fine for about 2 years and today the car just stop beeping when I lock or unlock the car please help
Was this "beep" from the horn or a siren? The unit could be in valet. Look at the LED on the antenna. Is it on solid? If so the system is in valet. To remove valet, turn ignition on then off, press and release programming button on antenna.
If the LED is not on and, the "beep" came from the siren then, there is an issue with siren itself.
Jan 16, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have encountered a high and low beep from my mother board, what would be the problem of my board and solution of this problem? but before i have first encountered a constant reboot of my computer it just...
Remove your processor cooling fan from the processor, then clean the fan with high pressure air blow and clean the top side of ur processor, and get a good heat sink solvent {not the white one}
it will come in grey color 10ml package i think, and apply half of that and fix... Actuall mean for the siren is system halted with thermal shutdown...
Sep 17, 2010 | ASUS Computers & Internet
System worked for 2 hours then shut off came back on a few times
It shuts down to protect itself from overheating, looks like you tried to use it too much without sorting the problem out.
You can try and give it a good clean out. Google cleaning computers.
I usually use a small brush, my vaccum cleaner and sometimes an air duster
Jul 26, 2010 | Spherex Xbox 5.1 Surround Sound System...
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Cannot boot the system.
When you put the RAM back into the computer did you return them to their original bank? Dual Channel DDR RAM is particular about being in shared bank with the other RAM module; that's why the color code the RAM Sockets in some motherboard designs so you don't them mixed up. Moreover, is the CPU fan spinning for the short time it is powered up?
Nov 27, 2008 | Intel D945GNT Motherboard
Bmw e36 1996 318is
If ews2 alarm is fitted it need to be reset by computer. Any tampering will set it into protectction mode. Had similar problem. You can try the following but if it does not work get someonr with diagnostic computer. PREPARATION 1. Close all doors, trunk, hood and sunroof. 2. The security system must be in 'disarm' mode. The key must be removed from the ignition key slot. ENTER CODE LEARNING MODE 3. Open trunk and leave it opened. 4. Open the drivers door and sit in the drivers seat. 5. Close the drivers door. 6. Cycle the ignition switch 5 times between the 'OFF' position and position 2,(ignition 'ON', all dash warning lamps will illuminate). The red status LED will illuminate continuously, and the siren will 'chirp' once, to indicate that the code-learning mode has been initiated. ?Do No start the engine.? The Ignition switch cycling in step #6 must be performed within 10 seconds. The sequence in steps #1-#6 must be performed within 45 seconds. REGISTER/DELETE ID CODE(S) 7. Open drivers door, (remain seated in the drivers seat) 8. Close the drivers door. 9. Press and release any button on the remote you wish to register in the system. The status LED will shut off momentarily to indicate that one code has been registered. 10. Repeat steps 7 thru 9 to register the three ID codes. It is possible for the system to memorize a total of 4 different ID codes. As a new code is initialized into the memory, the oldest code is automatically deleted. If you had lost your remotes and wished to delete the lost remote ID codes from the memory, you could initialize the ID codes from a newly purchased replacement transmitter four times thereby deleting the previous ID codes from the system memory. EXITING CODE - LEARNING MODE: 11. Open drivers door, and exit from the vehicle, leaving the door opened. 12. Close trunk. 13. Close drivers door. The LED will turn off and the siren will 'chirp twice. 14. The initialization procedure is now completed; Test all remotes to confirm operation.
Jul 01, 2008 | 1996 BMW 318
Change RAM
If you put the original RAM back in (both sticks) does the system boot?
Jan 15, 2008 | AOpen XC Cube EA65-II Barebone
Computers & Internet Logo
370 people viewed this question
David Payne
David Payne
