Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do I make my oiler work, my chain is not getting oil. I have a Husqvarna 435 chainsaw
  • Husqvarna Master
  • 2,239 Answers
Remove the oil pump and check for dirt and debris in the oil way, there is a pick up filter sited in the base of the crankcsae, you will need to look between the spine of the fuel tank to see the screw slot plastic retainer.
Posted on Jan 14, 2011
I have a huscavarna 435 chainsaw and after running a few minutes the chain locks up
You may have the chain tensioner set a little too tight.
Additional things to check:
  • The sprocket on the end of the guide bar is greased, and turning smoothly.
  • The chain brake is working correctly (not dragging or only partially disengaging).
  • The guide bar is straight, not bent or twisted, burr free, and the groove the chain travels in hasn't been squeezed together.
  • The chain tension is set correctly.
  • The chain oiler is functioning correctly (and you have a sufficient amount and correct type of bar oil).
  • Chain is in good condition, and the correct one for the saw. Make sure all of the links flex smoothly.
  • Chain is sharp. A dull chain will put more pressure on the guide bar because the cutting teeth aren't digging into the wood efficiently (and usually a person pushes harder on the saw when the chain is getting dull).
Chain side tensioning
http://husqvarna.custhelp.com/app/answers/detail/a_id/590/kw/chain%20tensioning%20screw/related/1
Mar 21, 2016 | Husqvarna Chainsaw Model 435 16" inch bar
Chainsaw chain keeps getting tighter when using?
this is a sure sign of chain overheating , due to not enough oil to bar , this will eventually cause bar to wear down and chain to not stay on
ck your oil pump and oil tank for proper operation
Aug 25, 2015 | Husqvarna 435 - 16" 41cc Consumer Chainsaw
HOW AND WHERE TO ADJUST THE OILER ON THE 240 HUSQVARNA
The Husqvarna 240 does not have an adjustable oiler. Always use good quality bar and chain lube, never motor oil.
Jun 14, 2014 | Husqvarna Garden
Can't seem to get my oiler to work properly. oil emerges when i run the saw with the bar removed, but chain is dry and hot when run put together.
Some saw manufactures design their oilers to only work with their bars. Are you running the mfg suggested or stock bar? Chain? Stihl Chain is designed to use 30% less oil because of oil groves cut into each drive link directed to the rivets. So if your running an aftermarket bar/chain, the oiling ports may not line up. Especially if it oils with no bar & chain
Oct 09, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna chain saw oiler problem
I fear you are correct about the oiler problem. I see a lot of oiler problems on these saws. Sooner or later Husky will have to address it. Ask the dealer about modifying your oiler; the 350 has an adjustable and might fit 1 or both of these saws. I think Husky needs to admit the nonadjustable is a mistake, and come up with a fix.
If you want to do some research start with the IPLs here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Please post back (below) with what happens at the dealer. Take your buddy and his saw with you! Good Luck. HTH
Lou
If Husky starts modifying all these with 350 oilers I want compensation...LOL
Feb 17, 2010 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Oct 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Bar oiler not working
The chain oil pump must be worn. The pump is fitted behiend the clutch and chain drive.Remove this by turning clockwise.
May 16, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Apr 10, 2009 | Garden
Chain oiler inop
this is a common problem and requires replacement of the pump. remove the bar and chain, the pump comes loose with a few screws. under it you'll see the filter which could be clogged, but not usually as contaminants are not likely to enter the tank. Small engine shops can order the new pump for you, hope this helps
Dec 22, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
790 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
