Question about Maytag Neptune MDE6700A Electric Dryer
MDE6700AYW dryer is making a very loud noise when drying. Also shaking the whole house.
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Posted on Oct 10, 2010
I had the same problem with my neptune making a metal to metal grinding noise less then 2 years old. the welded seam in the drum seperated causing the drum to be out of a round factory defect. Check that out as well, they had several units with this problem as i was told and maytag fixed it and picked up the tab.
Posted on Dec 03, 2010
Whirlpool dryer leq8611lw0 shakes violently and makes loud noise
Something must be inside the blower wheel. I cannot imagine why it would shake like that. This dryer has 4 wheels instead of 2 so it oughta be stable. The only thing to do is get inside the machine and see what is causing it. The dryer with a filter inside is also sometimes known as a series 90 dryer. Look for some series 90 dryer videos on youtube. Like this crappy one I made:
Apr 22, 2014 | Dryers
Last week, I started the dryer and as the drum turned, the dryer made a shrieking sound as loud as a fire engine siren. The noise has now changed to a loud rumbling, like a truck engine, whenever we turn...
What is the make and model? This could be the belt slipping, the idler pulley worn out, the fan may have come off the shaft to the motor, something stuck between the drum and the housing or the bearing on the drum. To check these things, lift the top off after you unplug it. The top clips onto the sides and the front and you have to lift hard to get it loose. If you pry on it be careful not to damage the paint.
Jul 20, 2013 | Dryers
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
My dryer used to make very loud noise when it was on and took long time to dry them!now when i plug it in and turn it on it trips my electricity switch for the whole house!what could be wrong with it?my...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 08, 2011 | Dryers
Super super loud vibrating noise loud as race car 110 db i took apart and saw that the screws in the plastic housing surrounding the blower motor had fell out (all of them x4). because of that the...
yes the turbine blades are spinning very fast if the out of ballance this is whats making all the noise it will also shake its self to bits very soon change the turbine fan
Nov 28, 2010 | EuroTech EDC158 Electric Dryer
I have a front load affinity dryer and it makes a loud rumble noise and shakes the whole dryer it sounds like something is loose or off track
maybe your rollers or belt here is a website on rollers:
http://www.partselect.com/dryer+replace-rollers+repair.htm
Oct 27, 2010 | Dryers
Vacuum shaking badly right up to handle and very loud noise
Could be a broker motor retainer. There should be two motor retainers in this model, when one is borken, it causes the unit to
shake and vibrate.
May 13, 2010 | Hoover U5507900 Elite Rewind Bagless...
My dryer is making loud screaching noises. Everytime I turn it on to dry clothes is makes very loud screaching noises.
Sounds like it needs what are called glides or felt. This is what keeps the metal drum from contacting the metal housing. If this is let go too long the drum can be ruined
Dec 01, 2009 | Dryers
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Fisher and paykel dryer works but very noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 27, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Maytag Neptune MDE6700A Electric Dryer Logo
357 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
