Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Fridge is not turning on. Is there a reset button. Fridge could have been unplugged a little.
I unplugged my fridge to plug it into a power strip (so I could also plug my microwave into that plug), and when I turned it on again it's not making noise. Did I hurt the fridge?
should not have
I would suspect that the power strip reset overload button popped or there is a problem in the power supply
unless the fridge did not need the compressor running as it was cold enough and the compressor had stopped as per the cycle
Oct 16, 2015 | Refrigerators
My Vissani hmdr1030we stops working, the there is a box on the rear bottom portion that makes noise some times i can get it to work by pressing what appears to be a reset button
That white box is housing a timer and an overload protector. That orange dot isn't a button, it is the center shaft on the timer. If the timer is running it should be turning.
Simplest thing to check is the thermostat.
  • Unplug fridge
  • Open fridge door.
  • Thermostat is connected to the temperature dial.
  • Remove the one screw about 2 inches behind the temp dial.
  • Pull down that plastic cover
  • Thermostat has a black, brown, and green wire.
  • Disconnect black & brown, and connect them together. This bypasses the thermostat.
  • Plug in the fridge. If the compressor turns on the problem is the thermostat
  • I took mine out and sprayed it with electrical parts cleaner (can get it at an auto supply store). Don't know if it is fixed for good yet.
  • If you want a new one, I found it at repairclinic.
  • Repairclinic item #1550645. Manufacturer number 502407000304. In the picture you can see the number WPF5E, which is what I see on the one in my fridge. Price $38.15
Aug 21, 2013 | Refrigerators
I have a frigidaire fridge model # FSC238F7DSBA I had a blinking error of " E F" on the control panel. I checked out the error codes as well as called frigidare customer service and they both led me to...
After replacing the control board did you unplugged the fridge.?There is no resetting button.Unplugging the fridge for 1 hour will reset it.If still the fridge doesn't reset then leave it over night unplugged.
Thank you
Oct 19, 2010 | Frigidaire Refrigerators
We had to manually defrost our frigidaire elite refrigerater and now it keeps beeping. Can you tell me how to reset it so it will stop? It beeped all night last night!
Hi there.
Did you unplug it to defrost it? Try to unplug the fridge for about 10 minutes and then try again?
Most often it works. Resetting button on the fridge?
Iceman.
Nov 05, 2009 | Refrigerators
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Jun 18, 2009 | Freezers
My Amana refrigerator freezer is totally off.
Ouch!
You may have lost your fridge. Try This.
  1. Unplug.
  2. Take a table lamp & plug into socket where you had fridge plugged in. Turn light on. If it lights. Fridge is trouble.
  3. If no light check another socket make sure light works if it works your socket, wiring or breaker is your problem.
  1. If fridge check wire to & from fridge make sure it is unplugged feel & look for crimp or gap in wire.
  2. Check connection to fridge some have a reset button or overload fuse. Reset or replace if you find one.
  1. If socket try another socket see if fridge runs.
  2. If it runs you will have to troubleshoot house wiring.
Contact me if you need more help. Good Luck!
Please rate if this fixed or was helpful. Thank you.
Mar 09, 2009 | Amana ABB1927DE Bottom Freezer...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I have also turn the buttons off and on inside the fridge.
Feb 21, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
Water filter
The red warning light has to be reset manually - by pressing the Ice Type and Child Lock buttons together for 5 seconds. As for the taste, check the flow direction is correct on the filter and run a few litres of water off.
Apr 16, 2007 | Samsung RS2630SH Side by Side Refrigerator
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
132 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
