Question about Acer Aspire T310 PC Desktop
On switching the computer on monitor shows no signal. the cables are connected properly
  • Acer Master
  • 5,660 Answers
1) Computer unplugged from power, computer on a table, computer case open.
Use a can of compressed air for computers, and clean out the inside of the computer, and it's Power Supply.
[Viewing the front of the computer, the Left Side Panel removes. Two thumbscrews in the rear, slide the panel towards the rear of the computer]
2) Observe Anti-Static Precautions.
Your body carries Static electricity.
Static WILL fry out (Short Circuit) hardware components in a computer. (Processor, Ram Memory, etc.)
TOUCH the metal frame of the open computer case to relieve your body of Static.
Should you leave your computer in the middle of working on it, upon your return be SURE to Touch the metal frame again.
3) Remove the Ram Memory modules. (Ram memory 'sticks')
Clean the gold plated contact pins on the bottom of the ram memory module, with a pencil eraser.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
You can click on the photo to enlarge. You can enlarge twice.
Rub the eraser on each contact up, and down. You don't have to scrub it with the eraser, just use medium pressure.
(Both sides. All contacts. Just takes a few minutes.
The Acer Aspire T310 uses DDR Sdram ram memory. Just like shown in the link example above.
There are 184 contact pins. 92 on each side)
Once you have finished cleaning use air to remove the eraser dust.
If you have a can of compressed air for computers available, use it.
If not air pressure from your mouth will be sufficient.
Still no?
Then I suggest you have a bad Power Supply.
Weak voltage power rail.
(There are three main power rails for the power supply used in that Acer.
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail.
All are DC voltage.
Two D cell flashlight batteries produce 3 Volts DC)
With a Power Supply having a weak voltage power rail, there is enough power to light LED lights, maybe spin fans, but not enough to turn the Processor on.
A) ALL of the LED lights combined use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts
C) A typical Processor uses 51 to 125 Watts. Depends on what Processor it is.
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/ACF31F.pdf
Copy the above link, paste it in your address bar, press the Enter key.
It's the Service Manual in PDF file form, from Acer Support for the Acer Aspire T310.
Posted on Oct 10, 2010
When i switch on my pc the monitor display a blue power light for 5 seconds and then it turns to orange and nothing displays on screen.
Make sure you have connected the Video cable properly, Please disconnect the Video cable from the Computer and connect the monitor only to the power source. If you monitor shows anything like "Check video cable" or "No Signal" that means the monitor is working fine. You just need to connect it properly to the computer
For any further assistance feel free to get back with your comments .
Thank you for choosing Fixya
Nov 01, 2010 | Acer V193w LCD Monitor
My LCD monitor blinks after switch on the power. display appear and go blank again appears and go blank and again and again.......................
1. Make sure the computer is switched on.
2. Check to see if the monitor cable has bent pins.
3. Make sure the signal cable is properly connected to your computer.
4. The energy saving feature may be activated.
Thanks for choosing FixYa
Oct 11, 2010 | Philips 190B7CB LCD Monitor
Signal cable not connected
what do you mean? You are getting that message when you switch on? Have you checked the signal cable between your PC and your monitor? If you cable is connected properly and you are still getting that onscreen message, it means your monitor main board has failed, and if its out of warranty, its time to get a new one, because few repair shops will touch them, and when they do, it is not cheap.
Jun 18, 2010 | BenQ FP567s 15" LCD Monitor
No signal
check whether signal cable is connected or not connect it properly and latch the nuts also.the fault may lies in the cpu not in the monitor
Apr 11, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
When i turn my monitor on it goes on and shows the acer logo then says no signal and just goes off and this just happened one day i have never had any other problems with it before
If you monitor shows no signal that means it is not connected to the computer properly and not getting any video signals from the computer. You need to check the vga cable properly Try removing the cable from both ends and and reseat the cable. Try another VGA cable. If you are using a Graphic card make sure the card is connected properly
Please feel free to get back for any further assistance.
Jan 25, 2010 | Computers & Internet
When I turn the computer on, the light shines to show power, but nothing else. No beeps nothing. Monitor shows no signal
first of all,
turn the computer off from the power switch
unplug the power cable from the back of the computer from the smps
wait for 5 mins
connect the cable bak n try.
OR
this wuld require a bit of expertise so do it only if u can
unplug power cable
open the tower
remove the ram/'s
blow the dust away, put it bak
do the same with the external graphic card, if ne attached
MAKE SURE U CONNECT THEM BAK PROPERLY
try to power up ur computer then.....
Nov 01, 2009 | Computers & Internet
No signal to monitor.
1 st you directly connect the lcd to system and see it is showing the display and conncet the vga cable proprly to kvm output socket.
Sep 08, 2009 | HP TFT7600 Rackmount KVM Switch
No signal
This problem requires you to test both the monitor and the signal input form you cable tv setup. Set the monitor up on a computer and see if it works properly. If it does then you may have a problem with the signal conversion of the cable tv to the monitor. It also could be a weak signal that drops below the monitors sensitivity levels. Have your cable tv repairman check the signal levels on your lines. Another way to test this is to hook up is with a different monitor to test your setup and see if it works. If after testing you find, the monitor does not work properly, then you need to have it serviced. Hope This Helps.
Mar 12, 2009 | Envision 19" Widescreen Flat Panel LCD...
COMPUTER WON,T YURN ON
first of all,is your power cable properly connected to your system unit.if it is not,connect it properly and turn the system unit on again
secondly,make sure your signal cable from the monitor to the system unit is properly connected
after following these instructions,reboot your computer again.
thank you for consulting fixya with your problems
Feb 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
When i turn on my computer, it displays signal cable disconnect,and the restart switch doesnt function
try 2 check the cable if it is properly attached. try connect a different cable from your computer to your VGA
Jan 25, 2009 | Dell UltraScan P1110 21" CRT Monitor
Acer Aspire T310 PC Desktop Logo
203 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
