Question about HP EliteBook 8730w PC Notebook
Blank screen at startup blinking "dash" upper left corner. Tests performed showed all is ok
4 Suggested Answers
Santhosh_7
  • 233 Answers
SOURCE: HP Pavilion ZT1000 laptop won't boot
I recommend you to try the steps in the below link:
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&product=18703&docname=c00372205#c00372205_doc
If there is no issue with your memory modules and battery the issue could be with the hard drive. I suggest you to perform test the hard drive of your notebook.
Posted on Jun 26, 2009
  • 136 Answers
SOURCE: Black Screen with Blinking dash on upper left corner
Are the xp disks specific for that computer. The reason I ask is because when you changed the hardrive none of the components on your computer know what to do because you won't have any drivers.
Does your hard drive lights come on? Do you think the computer is trying to access your disk drive
Posted on Jul 08, 2009
nonontech
  • 4737 Answers
SOURCE: blank screen with flashing hyphen
If you can't access the Advanced Boot Options by pressing F8 and System recovery didn't help, I am sure that C drive partition is corrupted or bad which you need to format. But before you format it, you may try with a Windows XP Live CD and boot the system from the CD-rom and Ram as the memory. Windows Live Cd is very effective, you'll be able to see the contents and condition of the partition. This tutorial (with the application) [Click Here] will show you how to make a windows live cd, in your case, Windows XP Live CD, but you'll definitely need a Windows XP Cd to create the Live Cd.
If you could get a Windows xp CD, you may try booting from the XP Cd and check the partition or repair the system, but if the partition's file system has corrupted or become as "Unknown file system" you'll not be able to proceed forward, in that case, you'll need to use a bootable Data Recovery Software to get the data, like EasyRecovery Software.
If you are fortunate, you'll also be able to recover or move the files from the C Drive booting the system from the Live CD, but in most partition issues, this doesn't help.
There are many Free Live CD's online, if you know about Torrents, you can try a search, it's not related to copyright or licensed, Windows Live Cd's are made by users to use the CD for emergency.
Let me know if you need further help.
(Note: Some Corrupted File System couldn't be recovered, means you will be unable to recover the contents and the partition could also become a RAW file system)
Good luck.
Thanks for using FixYa.
Posted on Nov 17, 2010
When i start my computer , i see a blank screen and a dash is blinking on the upper left hand corner. i am not able to do anything besides (F12) boot system
just open the right side cover of your pc and unplug the powercable of harddisk and plug the otherone or same and then try again. chek all your data cables too.
Apr 19, 2011 | Computers & Internet
The # 4 key is seems to be messed up or sticking, when I push other keys #4 shows up behind the key I pushed, sometimes the fours keep going across the screen
Here are some diagnostics you can perform. If the tests fail then the calculator needs to be repaired.
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
Jul 26, 2010 | HP 48gx Calculator
Calc. asks to recover memory, display goes blank, keys beep
The following procedure valid for the HP 48G should work for the HP48GX.
Self test.
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
System Halt
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
Hope it helps.
Aug 04, 2009 | HP 48gx Calculator
The #3 key sticks and won't show on the display
Try the following procedure (valid for the HP 48G should work for the HP48GX.) If any of the tests fails the calculator requires service
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jun 30, 2009 | HP 48gx Calculator
HP48SX keeps asking to recover memory
Here is the procedure to test the good or bad working order of your calculator. The procedure valid for the HP 48G should work for the HP48GX. If any of the test fails the calculator requires service.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Mar 27, 2009 | HP 48gx Calculator
HP 48GX problem
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Sep 03, 2008 | HP 48gx Calculator
ON switch
.The selft tests will show you what is wrong, and if the calculator requires repairs.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jul 01, 2008 | HP 48gx Calculator
Dell Dimension 4600 PC Desktop
try safe mode f8 and go into msconfig and uncheak startup stuff ok
Jan 21, 2008 | Dell Dimension 4600 PC Desktop
HP EliteBook 8730w  PC Notebook Logo
263 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
