Question about Magic Mill DLX 2000 Stand Mixer
Dough hook i am trying to use the dough hook - but think maybe i'm missing something? i don't have the manual anymore, but attached the dough hook to the back, and the scraper to the back too. but in the middle over the bowl - where the dough hook comes to - is sitting just underneath the metal bar. I notice there are holes through both - am i supposed to have a piece that joins the two together? b/c the dough hook doesn't stay itself..... is there a manual/guide online where i can see a picture of how it's supposed to look when connected? thanks
If you r using it for dough use the roller and scraper it works much better. But if u want to use the dough hook the holes in the middle is where the knob and stick in the arm go into to hold the hook inplace and it also goes in the hole on the side near the scraper hope this helps
Posted on Apr 17, 2009
I can't get the dough attachment off my Kitchenaid stand mixer. I have tried oil, filling up the bowl with soapy water and letting it stand overnight, pouring teapot after teapot of boiling water ove
Hi Georgette
You need to encourage movement between the beater and the silver shaft it locks on to. There is nothing that you can unscrew to make it easier. Get a can of CRC and try & get it around the silver shaft at the top of the beater plus you should be able to get a bit in that side slot where the beater engages with that driving pin. Rock (twist) the beater side to side and slowly the grip will loosen and you will be able to encourage it off. Once you have it off you will need to clean out the CRC and polish up that silver shaft. Next is the more difficult part, you need to polish up that hole in the beater. What you are trying to do is remove the build up of flour in the hole so that it is pretty much shiny in there again without being significantly bigger than it was originally. I use a rat tail (round) file to do this job, you are just removing the darker build up in there. When done a good wash and dry and it will be like new again. Keep the hole clean of flour and it may not happen again.
Nov 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
Kenwood kmix
Buy a new dough hook
Aug 05, 2013 | Food Mixers
Dough hook will not come off
I had the same problem too. There should be maybe 1/4" of loose vertical play of the dough hook (or similar attachment) on the agitator shaft. The hook locks in place rotationally on the shaft until it is pushed up. Before you try to turn the dough hook backwards in an attempt to remove it, push it upwards and hold it up, then rotate.
May 22, 2012 | Hobart A200 Stand Mixer
How do i insert dough hooks into stand mixer professional 600??? There are no holes.
Your Flat Beater, Wire Whip and Dough Hook attachement ends should
look the same. They are inserted onto the beater shaft and held in place
by a single pin. The reason you cannot attach the dough hook to the
beater shaft because it is the wrong hook for your particular model.
Jun 11, 2011 | KitchenAid KP2671 Professional 6 Series...
I cannot remove the flat mixing blade, after mixing cake. It has never happened before, just doesn't move up down or sideways! it seems completely locked.
The blade sounds like it's jammed somehow perhaps simply with some food matter.
Ensure the mixer is not plugged in then try removing the bowl, locking the mixer in the down position and pushing up hard on the blade to try and dislodge it. If it comes free and lifts up then try wiggling and rotating it normally off the mount.
Sometimes with use the attachments can become slightly warped requiring more force to lift them before rotating off the mount.
I once used my own Kitchen Aid mixer with the dough hook attachment to make a whole wheat bread dough. When I was done the hook was a bit bent from the hearty dough. There was also some flour in the mount causing it to jam. Removing the hook attachment proved difficult but not imposable.
Good luck.
Apr 18, 2011 | KitchenAid Food Mixers
Dough hook stuck immediately after use
I just got my dough hook unstuck! The problem was the bolt at the top of the dough hook. This bolt is used to adjust the height of the dough hook. This bolt came loose while mixing and went up towards the mixer. The force of the spinning actually tightened this bolt against the mixer so when I tried to release the dough hook by lifting and turning, it wouldn't lift. The bolt was in the way! The solution is to loosen this bolt. You'll need a thin wrench that's about 15 mm. You can test loosening this bolt on the other attachments since they loosen in the same manner. You'll have to bend the white shield down slightly to get the wrench in there. It's a tight squeeze even with a thin wrench. Hold on to the lower end of the dough hook and turn the wrench counterclockwise when looking down at it. Once you loosen the bolt, you'll be able to turn the lower portion of the dough hook to lower it. Then you can lower the bolt further. Once you have them low enough, you can remove the dough hook like normal - lift and turn. Sure beats boxing it up, shipping it for repair and paying for shipping both ways!
May 03, 2010 | Cuisinart SM-55 Stand Mixer
No sticker/model number on the bottom of my stand mixer and am missing the paddle attachment and dough hook.
Since you have not given a make...I'll take a stab in the dark and bet you have a kitchen aid...simply because you mentioned the dough hook. Kitchen aid has 14 models of stand mixers. You can match yours up and look at available accessories at
Sep 01, 2009 | Food Mixers
I recently acquired a KitchenAid/Hobart Model 4C stand mixer for free. It seems to work okay but I?m in need of a flat beater, dough hook and wire whip as it came with only the juicer attachment. Do you...
A number of attachments were available for the 4C, such as a juicer, a meat grinder, etc., all of which ran off the PTO on the front of the housing.  The only beater, however, was the wire one.  No dough hook was ever made.  I have been told that the motor didn't have the necessary power to run a dough hook.
Jul 25, 2009 | KitchenAid Food Mixers
Viking stand mixer dough hook will not come off
Had the same problem with dough hook not coming off. Sent to a Viking dealer in Rockford and was quoted $600. to replace gear box. Took it back without repairs and call Viking listed in manual and sent it to them on a Monday and by Friday had it back fixed and no charge.DM
Feb 18, 2008 | Viking VSM700 Stand Mixer
Magic Mill DLX 2000 Stand Mixer Logo
320 people viewed this question
Top Magic Mill Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Magic Mill Food Mixer Expert? Answer questions, earn points and help others
