Question about McCulloch Garden
I have a McCulloch FR2.0 14 " chain saw. It will start but will not run but a few seconds( 20-30) with only the choke on. It will not start or run with out the choke. It also will die out when running when throttle is pulled. (slight or hard)
  • 1,040 Answers
Here is a Link to a couple of my Tips:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
These solutions should solve your problem(s).
If you need further assistance, just let me know.
Good Luck!
Jim
Posted on Oct 10, 2010
  • Jim Parker
    Jim Parker Oct 17, 2010
    Was this helpful?
    Jim
2 Suggested Answers
SOURCE: Need a manual, for McCulloch, FR2=0,
what is the fuel / oil ratio for McCulloch 2.0 14"
Posted on Feb 15, 2011
Carburetor adjustment
Generally if you will set the screws about 1 1/2 turns an choke it on start it will go if everything else is ok. The set screws to proper idle an high speed run. Those are very cranky saws so take a few aspirins it might help. Lol
Mar 22, 2014 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Mcculloch 210 strimmer lost power now wont start for more than afew seconds
remove the muffler and run it the mufflers plug up and restrick the exhaust some mufflers you can open and clean the screen
Sep 14, 2012 | Garden
Runs but quits
Probably gummed up carb. If you don't want to try to rebuild the carb, then try adding a really good carb / fuel injector cleaner to the gas/oil mixture. don't forget to use a very small amount, then run the motor as fast as it will go for short periods of time to try and dissolve the gumming in the jets.
Aug 28, 2012 | McCulloch Garden
I have a McCulloch MS1636NAV chain saw. The engine starts with the choke pulled out. When I push the choke in the saw dies. I've changed the spark plug, replaced the air filter. changed the gas, 40:1.
Its either sucking air in throgh a loose connection in the fuel line or the carb is stopped up. Take it apart very easy so you don't rip any gaskets, and clean evertthing with a can of compressed air blow all the tubes out real good. You may have to get a carb kit it that does not work.
But that sounds like what it is, running out of gas when you let more air to it.
Oct 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
May mac 110 starts then it stops. I choke it it fires then i unchoke it and it starts and stops running.
Try backing the choke off about 1/2 way after it pops, and allow it to run for a few moments on that setting. Once the engine warms up, you can back the choke off completely. My Mac mini has no primer bulb, which means using the choke in a similar manner. Don't forget to set the 'fast idle' button on the throttle before starting (blipping the throttle will release the fast idle button). Hope this helps!
Sep 09, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a Mcculloch 16in maccat 35cc chain saw
Does the chain turn freely by hand? Is it being oiled properly? Check the fuel filter, air cleaner, and muffler for plugging. Does 'feathering' the choke make any difference? If it helps, try turning the H jet needle CCW about 1/4 turn which should make it run more rich and 4-stroke until you are cutting which should immediately cause the engine to 2-stroke. Hope some of this helps!
Jul 21, 2010 | McCulloch Garden
I own a mccullogh 610 pro mac chainsaw left by the previous owner of our house. Unfortunately, there is no user manual. I am not familiar with chainsaws and am having trouble starting it. I put in a new...
You do know a chain saw is a 2-cycle engine and requires a mixture of Fuel and 2-cycle oil? This saw is probably 40:1 (1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil).
My procedure is better than the one in your manual anyway. LOL
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
McCulloch Manuals
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
Feb 23, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Mcculloch 3516 chain saw, does not always start.
It must have spark, fuel and compression to run. Your task is to figure out which is missing.
Sometimes electrical components quit operating once beyond a certain temperature. Does it always start cold and become tempermental when warm?
IMO most hard start problems on a chainsaw with a good fuel delivery system are flooded.
Start Procedure
Cold:
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
The 3516 is a MTD McCulloch (Chinese). These saws are in a class by themselves. Good Luck
Lou
Nov 15, 2009 | McCulloch Garden
Mcculloch 3216 starts few seconds and dies, choke must be closed.
after jerkin fingers bloody today same problem i took carb apart,,the old hoses deteorated an clogged screen on in take side/// inside of carb plate //of carb,,blew out with choke cleaner,, reassembled now runs well make sure to run same size hoses large an small,,as original other wise floods out,,,
Mar 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain saw starts runs, bur saw won't start next time it is needed, craftsman chain saw
Steam vacuum? no clue but on your chain saw make sure you check the choke. it would explain why it wouldn't start again.
Sep 27, 2008 | McCulloch MC1275 Steam Vacuum
Garden Logo
723 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
