Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 TV Lamp comes on then 30sec later gose off and Red light gose on. Lamp and Ballast already replaced.
Lamp
Posted on Jun 03, 2008
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
The Red Lamp light is on.
IF YOU HEAR A CLICKING, ELECTRICAL BUZZING. THIS IS NORMALLY THE BALLAST NOT BEING ABLE TO LIGHT UP YOUR LAMP.
Apr 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 52525 TV Red Lamp LED
340v should be on power pwb plug PL on the 1 and
5 (GND) pins for the ballast. and the ballast plug CN should also have the 340V with pin 1 of that plug being GND nd pin 3 should have the 340V If the PL plug on the power board is low the power pwb has a problem most likely the doubler circuit. If CN plug voltage is high say 360V the ballast is suspect.
Jan 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Red lamp button replaced bulb still wont turn on trys to come on then turns off then red lamp buuton comes on
Is all of your Fans running CK lamp fan if it stops running then lamp will not Light also Ballast board is what turns Lamp on
Jan 06, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi WD-52525 and replaced the lamp.
We have runn in to this with this type lamp, And we are a service center so we do hundreds of these. We too have had bad lamps straight from the box so best guess would to take the lamp back Mitshubishi will warenty the lamp for 90 days so act fast
Dec 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My WD-52525 green timer light keep blinking and the tv will not comes on
If you've never replaced the lamp on that TV, I recommend you do it. Most probably it reached it's average lifepsan they have and that's why you're not getting an image at all. Now if you already replaced the lamp and still have the same issue, it's most probable that the ballast is faulty, this is the board in charge of sending energy to the lamp so it can turn on. www.discount-merchant.com/?Click=48427
Dec 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 52525 lamp replaced, no picture, red light
You have to take the TV apart. Pull the electrical chassis out and look for bad electrolytic caps on the boards. The red LED probably means the 2 - 3300UF caps on the power supply board are bad. You can tell if they are bad by the fact that their tops are puffed up and they may or may not be leaking brown fluid. Compare them against the other caps on the boards and you will see how they have flat tops.
BUT before you take the TV apart you can check the error codes by pushing "menu" and "Device" at the same time and holding for about 10 seconds. The status light will blink two numbers. ex. one flash pause two flashes is 12 Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
or use this table -
You can buy replacement caps from Mouser electronics online. There are plenty of solutions detailing how to do this already posted.
Jan 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red lamp light with newbulb, won't come on error code 34
There are two 1000uf 16V capacitors on the PWB that cause that problem code 34 lamp abnormality. If you need more info let me know.
May 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
139 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
