Question about Mustek Bear Paw 4800 TA Pro Flatbed Scanner
Hello ! My name is Artur. I have an 4800TA Pro 2 Scanner and i can not scan my slides. I have windows 7 on my PC
5 Suggested Answers
SOURCE: mustek a3 usb 1200 pro scanner problem
I bought one a couple of years ago. After plenty of hit-miss after trying to get it to work on my fresh XP installations, I have a solution. Installing it the normal way simply doesn't work.
First, go to 'start', 'control panel' then 'system'. Click the 'hardware tab' then press 'device manager'. You'll see a list of hardware.
If your scanner is already plugged in, find it (it could be listed under 'imaging' or under 'other devices'. You should see a yellow exclamation point indicating it's there but not working.
If you go to 'control panel... system' first, and then plug in your scanner, it will pop up automatically.
Now, right click on it, select 'update driver'. A window pops up. Insert the CD, then select 'have disk' and install normally.
Installing the remaining software is optional (acrobat 4.05 and so on)
I've used the "Panel" to scan my pics. Working like a charm.
Posted on Mar 02, 2008
acsmappel
  • 61 Answers
SOURCE: no drivers found for mustek bearpaw 4800ta pro
well, you said that it has xp drivers, so just use those..... If you meant vista, then No....
Posted on Aug 04, 2009
SOURCE: Mustek Bearpaw 4800ta proII need Vista/Windows 7 driver
Download from HERE (33.7 MB) or HERE (79MB)
These drivers are for Vista.
If you need them for Se7en - in setup.exe file properties point "Install in Vista compatibility". My Se7en accepted...
Posted on Mar 13, 2010
Alamo308
SOURCE: How to scan slides with Visioneer 9520 USB Scanner - it scans who
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
Posted on Nov 29, 2010
Xerox 4800 one touch flatbed scanner My new computer has Widows 7 and the scanner will not work with it. Do I need another drive
Hello.
I am a Support Engineer with Xerox Scanners.
The Xerox 4800 do not have a supported Windows 7 driver. The scanner only supports Vista, XP, 2000, ME, and 98. I recommend trading the Xerox 4800 for a supported windows 7 scanner.
Please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Nov 21, 2012 | Xerox One Touch 4800TA Flatbed Scanner
Recently upgraded from Windows Vista to Windows 7. Where can I get correct drivers to run with my Nikon Super Coolscan slide scanner LS-4000 ED model. I have Nikon Scan 3.0 twain software. Stu Milligan
Hello there.
This will help you if you have 64-bit Windows 7, because officially, there is not windows 7 64 bit driver.
Just read and do everything.
http://www.earthboundlight.com/phototips/coolscan-vista-64.html
Otherwise, if you have windows 7 32bit click here:
link
To check bits, go right click on My Computer, Properties, and you will see it.
Sincerely,
Steve TM
May 28, 2011 | Nikon Super Coolscan 4000 ED Film Scanner...
Hi i have windows 7 how can i install xerox scanner 4800 one touch?
either the vista or xp version should work, a bit of trial and error
http://www.xeroxscanners.com/en/uk/products/X4800/drivers.asp
Apr 26, 2011 | Xerox One Touch 4800TA Flatbed Scanner
Driver for 5470c scanner will not work with windows 7
Hi ,
Scanjet 5470c does'nt work under W 7 . No drivers available .
Here are a few hints :
1° hint :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
In any case , no slides or negatives scans possible but the rest works .
2° hint :
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Regards .
Jan 06, 2011 | HP Scanjet 5470c Flatbed Scanner
Will this Visioneer 4400 scanner driver work on Windows 7?
Currently there is no driver available for win 7.But one of my friends had the same issue and he
fixed it by asking windows to automatically find the driver from internet and it worked for him.So I suggest you try the same,this is what you need to do
1) First go to control panel,then open Program and Features.
2) Uninstall any driver for the Visioneer 4400 scanner that you have previously installed and reboot the computer,if there is no driver installed then skip this step.
3) Make sure your scanner is connected to the computer,now right click on "My Computer" and click "Manage"
4) Now choose "Device Manager" from the left panel and it should list all the devices on your computer on the right side.
5) Now select the option "Scan for Hardware changes" from "Action" menu on the same window,you can also do this by right clicking on any of the device name in the list (ex,drivers,keyboard) and choose "Scan for Hardware Changes"
6)A new category named "Imaging Devices" should appear on the device list now and when you expand it by clicking on the arrow, it should show your scanner as "42 Bit USB Scanner"
7)Now right click on "42 Bit USB Scanner" and select "Update Driver Software".
8) Now choose the first option,"Scan Automatically for updated driver Software" and Windows
should automatically find a working driver and install it.Now your scanner should work.
Let me know if it helped,good luck!
Nov 30, 2010 | Visioneer 4400 Flatbed Scanner
Jan 18, 2010 | Office Equipment & Supplies
No drivers found for mustek bearpaw 4800ta pro
Jul 28, 2009 | Office Equipment & Supplies
Require driver for Ion Slides 2 PC ... using Vista 64 bit.
MY ION SLIDES 2 PC WORKED WELL WHEN I HAD VISTA BUT SINCE CHANGING TO WINDOWS 7 IT WILL NOT WORK WHEN CLICK ON AQUIRE I GET THE MESSAGE CANNOT FIND THE SCANNER. PLEASE CONNECT 35MM FILM SCANNER. I HAVE UNINSTALLED THE PROGRAMME AND REINSTALLED IT BUT SSTILL GET THE SAME.
Feb 22, 2009 | Office Equipment & Supplies
Mustek Bear Paw 4800 TA Pro Flatbed Scanner Logo
51 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Tony
Mike
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
