Question about Frigidaire FRS26R4A Side by Side Refrigerator
The ice coming from my ice maker tastes bad. What is the problem and how can I fix it?
    President:
  • 3,113 Answers
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Posted on Oct 30, 2010
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Whirlpool ED25RF Does ice maker have a filter? My ice taste funny and sometimes its dirty
The ice maker doesn't have a filter , the problem could be the ice maker itself that the tray ,which is made out of aluminum is losing particles.Look at the conditions of the ice maker tray ,if you see like white spots replace the ice maker.
Aug 30, 2009 | Whirlpool Refrigerators
Ice from ice maker taste bad and can not find a water filter on it.
I would install a filter inline on the water filter I have one under the sink and on the ice maker
Apr 14, 2009 | Refrigerators
Ice maker has bad taste and smell
Add a cap of Miltons or a couple of granules of pool chlorine. Allow it to stand for a couple of hours and then drain.
Mar 08, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Bad tasting water and ice from fridge and kitchen tap...
Hi!! change your copper line going to the icemaker and also install a water line filter you can buy one at homedepot easy to install and has instructions on how to...good luck..
Jan 05, 2009 | U-Line BI-95
Ice tastes bad even after I changed the filter?
allow your ice maker to dispose old water that is still stucked on its hoses, just throw those unpleasant ices's and water would simply replenishes with a a fres and good supply
Nov 27, 2008 | Refrigerators
Coffee taste bad
Coffee Tastes Bad- Cuisinart
1) Run 1 tsp lemon juice per 1 cup water through Cuisinart
2) Use filtered water
3) Replace the charcoal water filters every 3-4 mos
4) Use better coffee
-Tha Mp3 Doctor
Nov 12, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
the feed line of the water source is bad replace it you will also need to clean the ice makers insides to remove the rest of the contamination
and 2 more suggestions:1) change the filter - older refers have the filter in the water line serving the ice maker - newer refers have the water filter in the refer (it looks much like an auto oil filter); 2) do not store ice for extended periods when ice use is not high e.g. during cooler months. Unless you use a full basket of ice over say a few weeks you should dump all and start over periodically.
thanks.
Sep 16, 2008 | Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
379 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
