Question about Dometic RM2652 Refrigerator
How do you pull out the RV refrigerator to replace the drain hose. Our hose broke.
2 Suggested Answers
  • 127 Answers
SOURCE: Info on replacing drain hose on dometic model 2652
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
Posted on Jul 03, 2009
I bought a 1984 Georgie Boy nmotorhome, but I do not know how to hook up the drains for the sewer or fresh water. There's a door marked sewer, but no pipe there to connect to. can you help?
The RV sewer system should end in a 3", 31/2" or 4" black plastic fitting that has 2 to 4 plastic tabs that a flexible hose will lock on with a twist. The fitting probably has a cap twisted on. After the sewer drain hose is connected to the RV drain, and secured in the sewer, a 'T' handled pull rod should open the gate valve. Most drain the black tank first, then use the grey water tank to flush the hose clean. If the 'T' handles aren't in your sewer compartment, you'll have to look under the bottom edge of the RV to find them.
Mar 19, 2017 | RVs
Hi there, have a Hisense fridge model hr6tff526(s) which is leaking water from the inside,looks like its coming from the top where the fan is located.thx
Hi Kassem
It's probably just condensation water like what you get under an air conditioned car in the summer.
Usually in a Fridge they collect the condensed water and run it down a clear hose pipe to a plastic container at the bottom rear of a fridge.
This pipe can become blocked with food & junk & mould, mice etc.
Find one end and clear the obstruction. A flexible rod or wire or air burst.
Cheers
Example Repairs:
DIY troubleshooting and repair for RV refrigerator condensation drain tube...
How To Clean Air Conditioner Drain Water in Drain Pan
Fridge Leaking Inside Refrigerator Drips From Ceiling Defrost Clogged...
Sep 14, 2016 | Refrigerators
Where are the condensing water drains?on a Coleman RV rooftop air conditioner
The condenser drains for a roof unit drain on top of the rv. There are on hoses which divert the condensation to a location other than the roof. Are you trying to keep it from dripping down at the door?
Jun 28, 2014 | Dometic Rooftop RV Air Conditioner
Where is water tank drain valve?
Locate water tank, drain valve usually within a few inches of it and drain hose goes through the floor. Make sure to pull drain plug on your water heater or it will freeze up. Use a bypass connector to bypass water heater when pumping RV antifreeze through water system.
Nov 30, 2013 | Itasca 2013 Sunstar 27N
Can you tell me if the drain pipe in the freezer go straight out the back of the freezer or at right angles or whatever, ae we seem to have a blockage in ours and it will not drain uot at all. The fan is...
I have water next on the floor next to the refrigerator. Its ten yrs old and I checked the hose on the outside and it not draining out there at all. can I change the hose or something to fix it.
Jan 13, 2010 | Thetford RV Refrigerator - N510 Model -...
Water on floor
The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
Clean the pan with warm soapy water or warm water and baking soda.
If the pan rattles when it is replaced, it is too close to the compressor. Simply reposition the tray.
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve. The hoses may be loose here.
Nov 14, 2009 | Frigidaire FRT18G5A Top Freezer...
Hope this helps,
Jeff
Rate me please!!
Nov 10, 2008 | Dometic RGE400 Top Freezer Refrigerator
Dometic RM2652 Refrigerator Logo
405 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
