Question about Roper RS25AEXLQ Side by Side Refrigerator
We have a Roper side by side, it is only 4 yrs old. Frig side quit cooling, freezer was fine. We took everything out and saw ice build up in freezer behind a panel. We defrosted and placed everything back in, one week later it has did it again. It is iceing up and the freezer works but frig side quits blowing air. How do we determine what's causing this? We have been told element in defrost, or a timer, or a heater blower. How do we know? How do we check?
  • cowboy_shell Oct 10, 2010
    Need to change that model #, It is a RS25AGXNQ02, I picked wrong one on the original drop down list.
    Sergeant:
    Champion:
  • 351 Answers
Hi do you have a volt ohm meter pull the back out of freezer check the element see if it has continuity if so it may be the timer witch should be somewhere near the thermostat hope this helps you jim
Posted on Oct 11, 2010
MY ROPER FRIG.ISNT COOLING ON FRIG.SIDE .FREEZER WORKS GOOD
Check fans worrking ok, condenser clear and clean, vents fully open, freezer not iced up solid blocking airflow.
May 19, 2012 | Roper RS25AEXLQ Side by Side Refrigerator
Refrig. is 4 yrs old. Refigerator side just quit cooling. Freezer side seems to be working fine. Help!!! Samsung Model #RS267LBBP
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
GE frig/freezer side by side about 5 yrs
Bad defrost timer, most likely. It is not defrosting the evaporator, and therefore, no air can be passed over it. Hope this helps
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Frig shut off
my 7yr old roper refrigerator top freezer stopped cooling and freezing but the light was still on with no fans. I dropped the thermostat cover and jumped the thermostat wires,no help . then i removed the wiring harness from the defrost timer and jumped the #1and #4 .She kicked off. I then replaced the defrost timer and it is running fine now
Jul 16, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
The freezer is working the frig isn't
YES , you need to replace the thermostat timer,its a device that operates like every 30 min or so applying heat thru a black element to keep the freezer from not building up ice . hope this helps AJ
May 12, 2008 | Amana ABB1927DE Bottom Freezer...
Whirlpool Frig
Is that everything in your freezer or just in the fridge. Is this a frostfree model. Often if defrost fails in a frost free model then it is unable to duct cold air to the refrigerator side of things. To fix- turn it off for a day or two.
Mar 16, 2008 | Refrigerators
Roper RS25AEXLQ Side by Side Refrigerator Logo
85 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
