Question about Pride Jazzy 1113 Power Chair
I just put new batteries in my Jazzy 1113 and the lights on the controller just blink and will not come on. Is there any thing else I need to check?
    Novelist:
    Champion:
  • 232 Answers
Check this website to find the type of controller your scooter has. The number of blinking lights will give you an idea as to the the problem is. You may need to reset the system after replacing the batteries. Check your manual for troubleshooting diagnostic codes.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Posted on Oct 11, 2010
Pride jazzy 1113, controller light scroll back and forth, wont move, i bought one new battery, it has full charge other battery is a little over 10 volts. is there way to test charger with volt meter?
The voltmeter should read 29 volts when on. You should never replace one battery and leave an old battery in the chair. Replace them both at the same time.
Oct 17, 2013 | Pride Jazzy 1113 Power Chair
Jazzy 1113
check wiring and pcb in your chair...it may be loose connection in between the path
Sep 30, 2008 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1133 has new batteries. All lights are lit on the battery condition meter. Maximum speed/profile indicator constantly blinks no matter how many sements are lit. After I turn it off and waiting a...
If all lights are flashing excessive voltage has been applied to the controller system. 6 flashing lights on the 1133 indicates that the chair is being inhibited by the battery charger. Try unplugging the battery charger. Check you battery connections.
Mar 30, 2013 | Pride Jazzy 1113 Power Chair
JAZZY 1113 AFTER CHARGING 10 HOURS SHOWS ALL LIGHTS, THEN AFTER AN HOUR OF USE IT SHOWS 1 RED BLINKING. BATTERIES ARE ABOUT 1 YEAR, IT READS 26 VOLTS AT THE PINS ON CONTROLLER. ANY SUGGESTIONS?
Mary yep Even though the batteries are charging they are not holding the charge to provide enough power for the chair. Usually you have one battery that is weak and causing the problem but both batteries must be replaced. If Medicare paid for your chair then they will pay for 80% of the new batteries. You can contact the provider that sold you your chair and ask if they can replace your batteries. If not, you can contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to have tech come out and repair the chair for you and they will bill Medicare for the cost of repair. Hope this helps
Feb 28, 2011 | Pride Jazzy 1113 ATS Indoor Power...
The jazzy 1113 will not start, when you press the power button the speed light comes on gets full and then turns back off
How old are the batteries? If you've had them for a few years it might be time to change them. Even if batteries are charged correctly they eventually lose power with use and need to be changed. Here is a link to the battery needed for the Jazzy 1113 http://www.replacementupsbattery.com/UB12350-NB.html
Nov 08, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1113 will not charge, batteries are new, light blinks indicates charging when plugged in but fails to increase usage lights.
Most likely your charge isn't charging properly. You need a multimeter to test the voltage at the joystick. In the 3-pin femal connector measure the voltage across the two horizontal terminals. It should read about 24 volts. Now plug it into the charger and see if the voltage increases, if not, charger needs to be replaced. You can get one that plugs into the joystick on ebay a lot cheaper than going to the mfgr. about $50.00 or so. Even if the lights are blinking, it may not be putting out sufficient voltage to bring the batteries up.
Dec 30, 2009 | Pride Jazzy 1113 ATS Indoor Power...
My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Mar 31, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Pride Jazzy 1113 Power Chair Logo
275 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
