T370xwo1,,,baird 37inch....sound but no picture,,the back of the screen lights up for a few seconds and then goes off,,,any solotions,,,thanks
bluegreenash
  • 661 Answers
SOURCE: no picture just comes sound
sounds like the Backlight has failed, if you look closely at the screen you should be able to see the image changing, but as there is no back light there is no luminescense so it will appear black or grey, It is probably the backlight inverter or element that has failed, if this is within warrany organise with them to fix it for free,
Posted on Sep 27, 2007
Shuttle83
  • 1139 Answers
SOURCE: polaroid lcd tv sound only no picture
Hello dougie49
I would first check the back-light and the inverter. usually these are what causes the problems in LCD displays. If the inverter is bad most likely the back-light will have problems. If you need to replace the back-light 9 time out of 10 you will require a new display element.
I hope this helps
Thank you,
Henry A. McKelvey
Posted on Sep 21, 2008
  • 53 Answers
SOURCE: Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Posted on Apr 30, 2009
SOURCE: screen goes dark, sound goes quiet...
I have a sony KDF-E60A20 projection tv. The picture would go out for about 30 seconds and come back on. It would continue to cycle this way. The green power light would stay on and not flash. The sound would go off when the picture went out and come back on when the picture came back on. I tried taking the bottom cover off the back exposing the fan and blowed it out with a vacuum cleaner, also taking out the bulb and blowing it out. That didn't help. So I ordered a new bulb from Advancedlamps.com and that's what it was. I have now had it on and off for two days and no problems. Cost of lamp was $107.00 including shipping. Good Luck!
Posted on May 29, 2009
SOURCE: SOUND BUT NO PICTURE
I had the same problem today with the same symptoms. I tried a power reset, removing the cables, checked all inputs and got the same symptoms.
I found a temporary fix. When I turned the TV on, I immediately press the backlight but on the remote until the bar appears then lower the setting down to 10. This may take a couple of tries of powering the TV off/on. Once I got the setting lowered to 10, the picture stayed on. If you invoke any of the presets it will change this setting. I'm going to call someone and try to get more information on a permanent fix.
I hope this helps, at least I got the picture back.
Posted on Oct 05, 2009
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Baird tv has no picture but sound ok. picture lights up when turning on and off but then goes out.y
Hi Anon,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Jan 07, 2014 | Vizio GV47LF Television
My toshiba 40ft2u1 will not turn back on
I'm having the same problem right now. I get the green light for about 5 seconds (not Blinking) then the light goes out. No sound or picture.
Apr 05, 2012 | Toshiba Televison & Video
Baird 42 inch LCD tv turns on but has black screen but no picture or sound
I have a 42 inch baird tv it will show the blue screen for a couple of seconds and then there's nothing just a black screen
Dec 08, 2010 | Televison & Video
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
LVM-37w1 37inch LCD HDTV
It is worth fixing but you have to replace the power supply. It is a fairly common problem with the Westinghouse units.
Aug 14, 2007 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Big screen troubles....
It is either going to be a shorted blue CRT (picture tube) or a driver board for it. I suspect the CRT itself.
Apr 17, 2007 | Sony KP-53S35 53" Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
