Question about Dryers
Frigidaire crown series dryer no power
Will not power on. Checked the breaker, thats ok. opened back panel, all wires appear by looking at them to be ok. Wuld it be the switch or timer?
  • sweathaus Jan 25, 2009
    service plug wired wrong, loud pop when plugged in. Plug is now wired right, breaker is ok, but dryer won't start.
    Scholar:
  • 110 Answers
Bad thermal fuse
Posted on Jun 01, 2008
Kenmore Series 80 Dryer won't start after Circuit breaker was tripped
A breaker thrown that many times indicates a serious electrical problem. You need to have the problem taken care of by an electrician. You should be worried about the safety of yourself and your family.
That being said, I would guess that breaker has gone bad and needs to be replaced.
Dec 18, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
Frigidaire dryer crown series model #FDEB23SRGS1 will not start
Check the breakers first . Reset both poles even though they may not show tripped. The wiring t the receptacle or plug could be loose. Los check behind it behind the back panel.
Feb 03, 2013 | Frigidaire Dryers
Dryer wont turn on. Breaker in breaker box is fine. No light inside dryer. What's wrong?
Dryers run off 220v, and sometimes only one leg of the breaker trips. So you need to flip the breaker all the way off, and then back on. Sometimes the breaker feels off but is not fully reset. Make sure you completely trip it off then back on. Does the dryer light work now? Is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service technician.
Sep 20, 2010 | Whirlpool LEB6300 Electric Dryer
Dryer not turning on
Have you checked the circuit breaker? I would start there. Dryers run off 220v, and sometimes only one leg of the breaker trips. So you need to flip the breaker all the way off, and then back on. Sometimes the breaker feels off but is not fully reset. Make sure you completely trip it off then back on. Does the dryer light work? Is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service technician.
Sep 20, 2010 | Estate TEDX640JQ Electric Dryer
Having problem with my Electric Maytag. I push the start button and nothing happens.. The model bumber is pyet344ayw..
Have you checked the circuit breaker? I would start there. Dryers run off 220v, and sometimes only one leg of the breaker trips. so you need to flip the breaker all the way off, and then back on. sometimes the breaker feels off when it's not. make sure you completely trip it off then back on. Does the dryer light work? is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service tech.
Sep 20, 2010 | Maytag Dryers
Control panel not working
If you have power going into the control but it does not illuminate or respond the control will need to be replaced. Here is a link that should help http://appliancehelponline.com/dryerconsole.html These boards are very sensitive to power surges and are not repairable, they must be replaced.
Jul 27, 2010 | Frigidaire FEQ332E Electric Dryer
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
I have an older maytag Heavy Duty will not start at all.
Check for ~230 volts AC at the two slanted slots in the power socket. If zero or near it, go to the breaker panel (fuse box) and look for that voltage across the wire ends of the breaker pair (or fuses). If still nothing, one of the breakers (fuse) is open. Make sure that you have full voltage at the panel entry connections. If the voltage test at the power socket was ok, then the trouble is within the dryer somewhere--a bad relay or problems in the control module. You would need a wiring diagram to trace out problems in the machine. Get back to us if you are stuck and describe your trouble-shooting efforts. Good luck!
Jan 04, 2010 | Dryers
Kenmore 400 series dryer won't start
If you checked the voltage at the terminal block on the back of the dryer while it was plugged in, you should have gotten the following readings:
RED to BLACK = 220-240VAC
RED to NEUTRAL (White) = 110-120VAC
BLACK to NEUTRAL (White) = 110-120VAC
NOTE: If the wires are not color coded at the terminal block, the OUTER two wires (LEFT and RIGHT) are the HOT leads and the center conductor is the NEUTRAL.
If you got anything other than these readings, you may have a bad power cord or a service breaker tripped. Some homes use two separate breakers to make up the 220 service instead of one single 220 breaker. If one breaker is tripped, the dryer may or may not start, depending on which leg it is. Can you please confirm your readings?
You need to confirm you have the proper input voltage before assuming you have any bad components.
Sep 05, 2009 | Kenmore Dryers
Frigidaire Crown series (FDGB34RGS1) doesn't turn on
This is more than likely a thermal switch that has gone bad. You will find it located under the top of the dryer. You will need to remove the top and find it at or near the drum. You can bypass it to see if that is the problem. If it is, you can replace it for about 25 dollars. This usually is the problem. If not, let me know back and we can go further.
Feb 14, 2009 | Frigidaire Dryers
Dryers Logo
505 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
