Question about MSI : P4MAM2-V (7095-010) Prescott/Socket478/VIA VT8751A/FSB533/DDR266/A&V&L/MATX Motherborad (MOT83) Motherboard
Components broken off
Thanks for replying, I have all that info, but that still doesnt tell me what the values are of the two capacitors that i have broken off. thats the first site i went to for info and for some reason they directed me to the fixya site.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
The pci and pci-e system needs a min of 2100 mf to 2400 mf
lala linda
Posted on Jun 02, 2008
Why does my tv turn off and doesnt want to turn back on?!
This can be caused by many problems. If the problem is intermittent, It can be a temperature issue. Electronic components change their value when they are at a higher temp or a lower temp. That being said, a component(most likely an electrolytic capacitor) is responding to this. So that means when the TV is warm the capacitor works normally which means the TV works fine. When the TV has been off and cooled down, if it doesn't start up, that could be why. This is just one thought of many. See if the TV works in a warmer environment and post more details of the issue if you would like further help.
Jul 24, 2016 | Televison & Video
Need to know the values on the duel compositor
The info should be on the side of the capacitor. If its not, it will be hard to tell by the capacitor. You will need to get as much info from the compressor & fan motor. Then call a local parts house(s) and find someone who can look it up for you. Or the comp manufacturer.
Jul 09, 2015 | Heating & Cooling
I have a philips plasma that turns itself off,tryin replace the caps 2465 2508 2540 2541, ive found the 100uf 16v wot will happen if i put a different degree 105 instead of 85
A temperature rating is not an electrical rating, and will not directly affect the electrical characteristics of the circuit. Higher temperature ratings only mean that the component will withstand higher temperatures. This can help provide stability to the electrical characteristics when the circuit is exposed to the higher temperature, and of course provide better longevity as a result.
Most electrical / electronic components that have values that can be changed usually can be changed to HIGHER values, nearly never a lower one. Capacitors may be substituted with others that have higher ratings in temperature, accuracy and voltage. Their unit of measure is the farad. In some very specific cases, even the farad rating can be increased. Inductors are similar to capacitors. Their unit of measure is the Henry. The Henry value, like the farad, should remain a constant. Like the farad, the Henry value as a rule however should not be deviated unless you know what you are doing. Resistors can have their wattage and accuracy values RAISED freely without fear of adversely changing the circuit. Increasing them usually provides better stability.
So, why not use components with these higher, more desirable values? Easy! Space and money. The higher wattage values require more space as they device is physically larger to dissipate the heat. Higher accuracy requires tighter controls on raw material grading and production processes.. all of this translates to more labor and higher costs. It doesn't make sense to buy an expensive 100v rated capacitor for use on a 5v circuit - when a 20v capacitor will be more than adequate - for a fraction of the cost.
I hope this helps and good luck! please rate my reply. thanks.
Jun 06, 2011 | Philips Televison & Video
Iam trying to find the value of a capacitor which is damaged on the GPU board for the following product. Nvidia 9800GT 1GB graphics card. The component is situated at the top right hand side of the GPU...
1) Whatever company that made that Nvidia 9800GT graphics card, isn't going to produce a schematic for the general public.
(EVGA, VisionTek, Galaxy, Sparkle, BFG, etc.)
They paid big bucks to Nvidia for the GPU, the schematics, and all licensing fees.
2) If you indicate that you believe most of the capacitors, (Radial Aluminum Electrolytic Capacitors), are of the same values, capacitance, and voltage, then remove another one of them, and test the capacitance.
Multimeter set to OHM's. An economical unit can be purchased for around $5 to $12.
Most auto parts stores carry them, as well as a multitude of other stores.
3) The Radial Aluminum Electrolytic Capacitors you are looking at, have the values printed on them. They are just in the capacitor manufacturer's code.
http://www.hardwaresecrets.com/article/595
Page 2 of the article starts with the identification of the markings.
Page 3 dealing with capacitors manufactured in Japan.
Page 4 deals with capacitors manufactured in China, and Taiwan.
Regards,
joecoolvette
May 30, 2011 | Computers & Internet
The left brake light does not illuminate
You serious ? I think the flux capacitor is gone !!
Jan 17, 2011 | 1998 Land Rover Discovery
Sharp Aquos BD-HP20 Power Supply - Burned Out Cap C911
The capacitance of the capacitor C911 is 330uF/200 volts.
Feb 12, 2009 | Sharp AQUOS Blu-ray Disc Player
Kds vs-f14
There is usually an identical resistor somewhere else on the circuit board, so if you cannot read the colors of the burnt one, you can read the colors from an identical resistor on the same board. If you just replace the resistor, it will probably just burn out again or damage another component, you have to find the cause of the resistor burning out, most likely an electrolytic capacitor failing. Look for bloated or seeping capacitors and replace those as well. Also look for broken or burnt toroid coils.
Jul 15, 2008 | BenQ FP731 17" LCD Monitor
P4004 - Blown Components
if burned components are on output stage or amplifier section on board..Then look at the oposite side of amp..Both amplifier section should be a mirror image oof componentc from other..that way you can know the values of parts.If they are on power supply section ..Then you might need manual if available..
Dec 23, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Need some parts for BNT1500AP
If you can find a manual - you probably will not find parts- total board replacement or unit replacement is your only route Do come back to tell me I am wrong - it will be invaluable info for all of us.
May 17, 2007 | Powercom (BNT-1500AP) UPS System
MSI : P4MAM2-V (7095-010) Prescott/Socket478/VIA VT8751A/FSB533/DDR266/A&V&L/MATX Motherborad (MOT83) Motherboard Logo
49 people viewed this question
Top MSI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Mark Taylor
Mark Taylor
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
