Question about Emerson EWV403 VHS VCR
Recording a tv show on a emerson vhs recorded problem
When I put the vhs tape in and turn on the power button the televsion program goes away and looks scrambled and fuzzy so I don't think it will record.
Allow the VCR to perform the much needed channel set up process... after this procedure, you will be able to record error-free...
Posted on Jul 05, 2008
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
I have an old emerson TV/VCR (Digital Tracking VHSHQ) The TV works fine, but when I put a tape in it is ejected and part of the tape stays inside, but can be pulled out.
Try a VHS Cleaning Tape Cassette. Follow it's instructions. If no better result it's not worth throwing away money on having repairs done but better put toward, if you can afford to, buying:
Option 1. A VHS/DVD player (combo as these are known) and plug that into the Emerson AV input.
Option Two: A VHS/DVD twin recorder combo deck - and plug that in.
Then start on copying any VHS tapes you cherish to DVD on this device.
Option Three: Forget the Emerson except for just using as a TV and buy a new TV with DVD player built in - the latest type of combo.
(I'm having to guess whether you've just used tapes to watch or record and watch)
Sep 26, 2011 | Televison & Video
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
How do i record a show onto a tape?
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording
the VCR clock / date must be set and not flashing 12:00
then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording
a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
Dec 26, 2010 | Sony SLV-678HF VHS VCR
After vhs auto rewinds both it and TV power down
some televisions have a feature where the video signal disappears,they power off.when the vcr shuts off,the signal goes and the tv shuts down
Jul 07, 2009 | Emerson EWV403 VHS VCR
Zenith xbv713 won't record on vhs tape
is the tab on the cassette in place? if it has been removed the cassette will eject automatically when pressing the record button.
Jan 05, 2009 | Zenith XBV713
Stupid question recording on a vcr
If you have a cable box:: the RF cable from the outside to BOX, the BOX to the INPUT of vhs video, the OUTPUT of video (VHS) to the back of TV.
Keep the channel for the reception of tv through CABLE BOX according to cable box directions.
Put the ch. on the cable box to ch. u want to blank vhs tape ( with the TAB in back NOT broken off ) press [record] usually red button.
Oct 27, 2008 | Televison & Video
Can't get movie to play
Are you trying to record on a protected tape? Does it do this on all tapes?...accordianman
Feb 18, 2008 | Emerson EWV403 VHS VCR
DVD Player/Video Cassette Recorder
Hi It sounds like possibly there is stray RF getting into your video signal from your DVD/VCR combo to your tv. Check that your cables are ok, but also, if you can, try moving the unit in relation to the tv, if it is underneath, try putting it on top or beside the tv, I've seen the effect you describe be cause by lack of sheilding in both the tv and DVD/VCR, and moving the unit could cure it. Good Luck!
Apr 02, 2007 | Sanyo VWM-900 VHS VCR
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Emerson EWV403 VHS VCR Logo
96 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
