Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Unplugged my WD Passport from my Mac without ejecting it. Now don't get an icon on screen, and doesn't work on any other computer either.
SOURCE: dropped a WD passport drive, now it won't load. HELP!
Unfortunately, these drives are not made to be dropped.
It sounds like it was damaged by the drop which could have rendered the read/write heads inoperable or mis-aligned.
Contact Western Digital for a warranty replacement.
Posted on Apr 29, 2008
SOURCE: WD Passport not recognized anymore
Change your USB cable, I had same problem...changing the USB cable woked for me.
Posted on Oct 22, 2008
marketex
  • 371 Answers
SOURCE: unplugged My Book USB port without ejecting 1st - all data lost!
I wish I had the words of comfort that you will need with this tale of woe I must tell you.
You see, its a matter of organization.
Though your data is SOMEWHERE on the disk, without proper ejection, the disk cannot find them as they had been assigned data space.
It is very much like the requirement that a computer be properly shut down or face similar problems with its internal disks becoming corrupted.
Your files were not actually cleared, they were corrupted, but perhaps the volume can be repaired.
Go into your applications folder, (as you should have done while installing the disk in the first place) and find a folder entitled "Utilities" and within that folder and icon entitled "Disk Utility" and click on it. and a dialogue window will open up showing all disks currently installed, including your external disk which you should select and you will notice tabs entitled "First Aid" "Erase" "RAID" and "Restore"
Follow the instructions found there and the very best of luck to you.
Posted on Apr 25, 2009
SOURCE: my wd passport wont even come up
I had the same problem with my passport-mac connection. When i first purchased the passport and plugged it in, I had no problems, the icon came right up on my desktop. Then i backed up my entire computer which is only about 25-30 GB. After that, when I plugged the passport in, it didn't seem to be recognized but the light came on and the drive made noise. I searched for answers, and even considered downloading some of the stuff people recommended. But then I realized, if I let it sit, after about 20 minutes, the icon popped up on my desktop. I am not a computer person, but to me, it seems that because there is a decent amount of information on my passport (although no even close to full) my computer needed some time to read the entire disk in order to use it.
Hope that helps.
Posted on Aug 11, 2009
SOURCE: the 250g wd hard drive icon disappeared from the
If they plugged it into a WinPC, the PC won't be able to read the drive.
More then likely the SATA-to-USB card in the drive has gone bad (like mine did.)
I ended up buying a rocketfish 2.5" SATA HD enclosure kit from BestBuy... now my drive works fine.
Good Luck!
Posted on Oct 18, 2009
Hav e new WDElements 3TB USB ext Back up drive...fired it up 1st time, MAC desktop has the WD icon on desktop on it, but cannot copy any data to it. In the corner of the element window there is a pencil...
https://support.wdc.com/knowledgebase/answer.aspx?ID=15084
The link above states:
"My Passport for Mac and My Book for Mac are formatted with HFS+ and are Mac Ready
  1. To use the device on macOS and for Time Machine backups, format the drive as HSF+.
    For assistance formatting the drive for Mac usage, please see Answer ID 3865: How to partition and format a WD drive on Windows and macOS
  2. To use the device on macOS and Windows OS, format the drive as Answer ID 291: How to format a WD hard drive in exFAT or FAT32
  3. Click here to download WD Software for macOS
Feb 11, 2018 | Western Digital 3TB My Book Essential USB...
I'm not able to write files to my WD passport drive. It works fine in XP, but I have a Mac only..really not sure wat to do here..sos!
If the WD has been formatted in NTFS then the MAC cannot read or copy to this hard disk.
To make it compatible for the PC and MAC, format the WD Passport drive on your XP computer in FAT32 format. Then you can copy and exchange files between the PC and MAC.
Dec 26, 2010 | Computers & Internet
Accidentally removed WD My Passport for Mac without ejecting first. All files are still there, but I get an error when trying to open them. How can I fix this. TONS of stuff I can't lose...
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 11, 2010 | Western Digital WD Passport 250GB Portable...
In hurry, I unplugged my WD Passport (400U017-RTE), I had a folder open which I thought was from PC "My Documents" but unfortunately no. When I plugged my WD Passport, it could not be recognized i.e. I...
Plug in the drive and, on the status bar next to the data and time there will be an USB icon Click on "Safety remove hardware and eject media". Once its says its safe to remove media, unplug the hardware and plug it in again after a few minutes and it should start working again. If it still does not work you need to delete your USB driver from system setting and reinstall the driver.
Feb 11, 2018 | Western Digital Passport WDXML800UE...
I have a mac Book Pro and have been backing up my photos to a WD Passport external hard drive for several months now. This morning the Passport did not even show up in the finder window. Its' Smartware...
Try plugging into another computer and if that works save all your data then format and try back on your own computer. If this doesnt work start to look into data recovery software. I use 1 called GDB (Get Data Back) which will read a lot of drives information when operating systems wont. Good luck from Scott
Jul 12, 2010 | Computers & Internet
Hi- I've just inserted a CD into my MacBook Pro
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Oct 13, 2009 | Apple MacBook Pro Laptop Computer with...
WD passport fried I think. Can I reformat?
Well in this case, formatting should no be performed. the Western Digital data recovery tool should be taken a try first of all. If it doesn't help, then take the device for data recovery services if the data is really important to you.
Remember - DO keep the deivice safe from data overritten or physical damage. Regards.
Aug 13, 2009 | Western Digital WD Passport 250GB Portable...
My wd passport wont even come up
Does it currently connect to any other mac or pc???
If someone "yanked" it out while it was still in use, it could have corrupted the boot sector of the drive containing basic information about the drive that allows it to be read properly by the operating system. If this is the case you can recover everything without any data loss within minutes. Look over the following program, TestDisk v6.11.3, and see if it's something your willing to try. It's 100% free, no spyware, no viruses, no adware:
(Note: if you use this, you should experiment with it first on a usb thumbdrive you're not using until you feel comfortable with it)
TestDisk Information
http://www.cgsecurity.org/wiki/TestDisk
TestDisk Step By Step
http://www.cgsecurity.org/wiki/TestDisk_Step_By_Step
TestDisk Download
http://mac.softpedia.com/get/System-Utilities/TestDisk.shtml
or
http://www.softpedia.com/get/System/Hard-Disk-Utils/TestDisk.shtml
Aug 10, 2009 | Western Digital Passport WDXML800UE...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
314 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
