Question about Sony Playstation 3 (PS3) Console
My plastation 3 keeps crashing. sometimes i see a screen and it is playable for a little bit before crashing and sometimes i dont see a screen at all
    Genius:
  • 1,175 Answers
HI...
Try dusting it out with a can of compressed CO2. Shoot it into the spaces that you can fit the nozzle into. The try again
Posted on Oct 10, 2010
Dash problem diesel navara d22
see the diagram attached and proceed for troubleshooting . God bless you
Jul 02, 2012 | Cars & Trucks
When i click on training it causes a crash dump
here are instruction to fix crash dumo to your sega football manager 2011
Step 1shock.gifpen up your steam
Step 2: Go onto your games list
Step 3: Right click on Football Manager and select properties
Step 4: Select the Local files tab on the far right
Step 5: Click the option Verify integrity of game cache
Step 6: Click the option Defragment game cache
It should now be complete
this worked for me
I'm sure there are other people out there who have had there game destroyed by Crash Dumps errors, sometimes screwing your save, sometimes even preventing you from starting new games forcing you to re-install only to come across the same problem later down the line.
So here is my 2 part guide to Crash Dumps, part 1 is how to set your game up to minimize the chances of your game ever getting this error, and part 2 is what to do to recover your save (If possible) and get your game back to a working state if you had this error already. Part 1 pretty much lists all issues that cause Crash Dumps and to set your self up to prevent it from happening.
Crash Dumps Prevention
There are certain things that increase your chances of getting an error, here is a list
1) FMRTE - Just dont go there, it screws your data base up beyond repair, you will not be able to get your corrupt save back if you have used this editor. Sometimes its been to known to cause damage to your windows registry too, unless SI make an official in game editor, using third party programs like this is all to risky stay away.
2) Size of Game - Even though I believe I have found the solutions to 99% of crash dump issues, it does not change the fact the game is not without major issues, the games coding causing endless memory leaks that lead to Crash Dumps errors.
So what I'm saying is try to go easy on your database size, either slow or at most medium size data base when starting a new game.
Also dont go crazy with the amount of leagues you select to be playable, if you have a good system 10 leagues at max.
If you must have lots of leagues and large data base I recommend you have at least 6GB of DDR2 or DDR3 ram, if you have an older system DDR ram will not cut it for crazy data base sizes.
3)Everything Up to Date ? - Make sure the following are up to date
+ Graphics Card Driver (Use manfactures site, sometimes windows will not find the most up to date driver)
+ Java - Make sure you have the latest Version
+Direct X - Latest Version your system is compatible with
4) General Settings in Game These are optional but I recommend you use these settings to prevent errors.
Uncheck the following boxes
+Use Skin Cache
+ Enable Data Collection (This is an important one, it will stop FM constantly building up the RAM useage and prevent Crash Dumps)
+ Play in Windowed Mode, Minimize, and Maximize Every Hour.
+ Disable sounds, and 3D cameras, the 3D sucks anyway text all the way.
+Play with Autosave weekly, 3 file rolling save for back ups, better safe than sorry.
+ Uncheck Threading, if you have a Dual Core processor, you do not need this to be checked, it takes away a complication. However if you have one processor with Threading technology keep it ticked, other wise the game performance will be poor.
5) Your Hardware Before Playing FM 2010 you need to be confident your hardware is all fully working, so you can rule that out if you need to trouble shoot in case you get the Crash Dump.
Consider and do the following before installing the game
+Power Supply - Is it at a high enough Voltage for my Graphics card ?, find out and upgrade power supply if need be, you should not be using a Graphics card if your power supply is under the recommended amount, your system will become very unstable, let alone Football Manager.
+Hard Drive Error Free, run Chkdsk, a windows tool to see if your hard drive has any errors.
To run chekdsk press the windows button and R, then in the run box type in CMD, the in the black command box type in chkdsk and press enter.
You should have a report of no errors, or windows will fix errors
+ Faulty RAM - This was the culprit for me, run a program called MEMTEST86, you need to download and Burn it to CD, restart your PC with the CD in the drive and let it scan.
If you are error free all good, if not note which RAM slot is reporting errors, remove or replace that RAM.http://www.memtest86.com/
+Dust Bunnies - Your system would be unstable in general if you have these, if it is a little unstable check the innards of your PC for obvious dust, blow to free dust from sensitive areas.
If you ever get Blue Screen errors while browsing, gaming, multi tasking, then Football Manager will certainly Crash Dump you ***.
Okay if you follow all these steps prior to installing your game you are very unlikely to get the crash dumps error again.
please rate me if this help you thanks...
Jun 05, 2011 | Sega Football Manager 2011
Plastation 3 wont load games tested blueraydrive in another console and it works everything else works can go on network and internet
It depends on the region that it is playable. I believe the reion code is the problem why it is not playing.
Or there are lots of scatches that the unit is unable to read
Nov 22, 2010 | Sony Playstation 3 (PS3) Console
When I try to turn my plastation 3 on the green and blue lights come on then a yellow light flickers and the plastation turns off
Sorry to hear that you have the YLOD (Yellow Light Of Death)
If you dont have any warrenty left on your ps3 then take a look at this guide how to fix YLOD. [ Link ]
If you still have warrenty left i advise you to use it.
I hope this can help you, best luck from here. :)
Oct 12, 2009 | Sony PlayStation® 3 (60 GB) Console
My ds just crashes--shuts down--when playing. Is
The same thing happened to my DS that was 3 years old. But at a point it didn't even turn on. The top screen made a quick blink then it turned back off automatically. I suggest you just get a new DS (I got a DSi) because a new battery is VERY expensive.
Answer:It is definitely the battery, though.
Jul 07, 2009 | Nintendo DS Lite Console
Beeps alot, while it take a while to load the page, and the video card stops working, it crashes sometimes have to reboot everything
problem: Overheating
Solution: Attach small fan over heatsink on video card also recommend rear case fan..Keep it Cool
Apr 16, 2009 | Computers & Internet
Turning on, crashing ans screen
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372718&lc=en&cc=us&dlc=&product=435618&rule=44570&lang=
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035372&lc=en&cc=us&dlc=&product=435618&rule=44570&lang=
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00037733&lc=en&cc=us&dlc=&product=435618&rule=44570&lang=
Jan 09, 2008 | HP Pavilion dv1000 Notebook
Acer 5050 crash problem.
It is highly unlikely its a crash......two operating systems cannot....CANNOT crash similtaneously. Its impossible! unless the hard drive you run both on is faulty BUT you wouldnt get Windows to load. Not even for a bit....you say all lights will stay if they were lit up but they some how dont stay on.........I think thats what you mean.........then you say you checked again and there were rectangles that look like a book that stopped blinking yet the power lite stayed on....Im at a lost But I dont think its a crash......only software crash it might be a hardware pronlem....
Sep 12, 2007 | Acer Aspire 5050-3242 Notebook
Sony Playstation 3 (PS3) Console Logo
53 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
