Question about Microsoft Xbox 360 Console
Overheats i just bought and instaled a xcm fan a clear case and some lights and after about 10 minutes of playing cod4 it gets 2 flashing red lights it shouldnt be doing this i put in a better fan and it is worse than the stock one. **************!!!!!!!!!!! p.s. the fan mode is automatic
  • 32 Answers
U need the cooling system for the bottom.
e-mail me at B3652@live.com
Posted on May 31, 2008
Two flashing red lights means it has overheated. Maybee it does have alot of ventilation but the dust may have ecumulated to an amount that can not escape the system case. Clean it really well with a can of compressed air and make sure fan is running in the back. Some fans fail but continue to spin so if it looks to slow it probably is. You can watch you tubes tutorials about opening and cleaning your console. Hope this helps. Good Luck.
Nov 23, 2009 | Microsoft Xbox 360 Console
Xbox 360 halo problems
my halo sometimes does the same thing when i start up the game but pressing a usually gets you through it, but if your xbox 360 overheats within minutes and is an older xbox 360 its usually a burnt out fan or just full of dust, if its old then ur warranty might already be out and if it is just open up the xbox and use an air compressor or anything else to get all the dust out of the xbox. in my case everything was just caked with dust. anyways... good luck
-Armand M.
Jul 24, 2009 | Microsoft Xbox 360 Console
2 red lights fans don;t work
Hey Marsh2Man,
It's not your fans that's causing the problem. It's the XBOX itself. The Xboxes generally overheat and this has been a big problem for Microsoft. Alot of companies are actually reflowing these system, reheating the solder under the chips allowing them to connect back down to the points on the board.
You will need your system reflowed. Contact a repair shop.
Jun 02, 2009 | Microsoft Xbox 360 Console
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
Xbox360 has 3 red lights
Its when the solder overheats and disconnects a wire in the xbox. If you have bought it within the last year, you can return or swap for new wherever you bought it. If not you will most likely have to send it off to xbox repairs.
Apr 01, 2009 | Microsoft Xbox 360 Console
Cant play games on Xbox 360 live
imma suspect its overheating. beings the fact youve experienced the red ring of death in the past. its either overheating or the hard disk is going bad. unless your using a memory unit. then id point the finger at overheating. the x360 is basically a computer. and when the cpu and gpu overheat or experience harsh temperatures they tend to run sluggish and their performance goes down the **** till they cool down or overheat to the point that the system locks up and crashes/hangs. if you can post more info as much detailed as you can i may be able to more help ya!
Nov 12, 2008 | Microsoft Xbox 360 Console
Screen shut down
hi furotte,
u have taken a right decision u havt to buy a new graphic cards while buying card just read the manual of cod4 it shows the latest graphics that supports the manual will be in cod4 game file
regards
shailesh
Mar 12, 2008 | ASUS EAX1950PRO/HTDP RADEON X1950 Pro,...
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
