Question about Frigidaire GLEQ2152ES Electric Dryer
My dryer won't heat up, it will start and it runs fine but it wont get hot. i just hooked it up and it was new but the warrantees expired on it so i cant take it back to the store. how do i make it heat up?
  • Frigidaire Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 10, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My whirlpool dryer wont start, I replaced the start switch and the door switch seems fine. I hear a ticking noise
The door switch may not be making contact. All dryers also have a High Limit thermostat that shuts down the dryer when too hot. The high limit thermostat should reset when the dryer is cooled off but may be defective. If the dryer is electric, 110 volts run the drum motor, and the other leg of the 220 line is for the heating element.
May 05, 2014 | Whirlpool Dryers
Whirlpool Dryer IED4400SQ0 wont get hot
Did you pull the element out and test it? I think it is your heating element. Visually inspecting is never enough. Just hook it up to high voltage independently to ensure it heats. It will turn red hot.
Mar 12, 2014 | Whirlpool Inglis IP8200 Dryer
The dryer wont stay on the heating mode
how long does it run before quit heating . unhook dryer vent hose and try with vent discounected
Nov 29, 2013 | Haier GDZ5-1 Electric Dryer
Dryer won't start
Either one or 2 things happened. The move cause the lint to shift around inside the dryer and it overheated blowing the fuse. OR the new apartment's vent is blocked and caused the dryer to overheat. All maytag dryers are not the same but they all have a non resetable fuse mounted on the blower housing. When the temp exceeds 350f it melts and kills power to the motor. If the motor is not running the heat does not get power. The motor must be turning to make the cent switch power up the heater. Dryer manuals
Dryer videos
Sep 03, 2012 | Maytag Dryers
Working fine this morn went to use again wont start
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 19, 2010 | Whirlpool LER4634J Electric Dryer
I have a Kenmore electric drier # 110.60912990 It runs fine, but no hot air. What should I check. I checked the outside vent and air is coming out. I check the circut breaker and it is fine.
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 03, 2010 | Kenmore 64942 Electric Dryer
New bike 2008 k1200 gt starting problem when hot
if the clutch burned out it must have been slipping causing lots of heat inside were the starter is, all this extra heat wont do the starter any good at all, if its still under warrantee get it back as its clearly not right,, not at all like bmw?
Feb 02, 2010 | 2008 BMW K 1200 GT
Dryer will not heat. lint filter is clean. dryer runs fine bosch dryer nexxt 500.
heatman101
Nov 08, 2009 | Bosch Nexxt 500 Dryer
2 dryers that run but have no heat
It sounds like the gas supply is not giving you any gas, as both have the exact same symptoms. You can see the glow coil getting red hot, then the safety shuts off after a it gets no gas. If you feel confident, shut off the valve in back coming from the wall, unscrew the line where it connects to the dryer. Turn the valve back on slowly, there should be gas pressure blow out of the line.
Dec 19, 2007 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
48 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
