Question about Samsung TV Remote Control
Need code for samsung remote control BN59-00602A to operate with amino a110 stb
5 Suggested Answers
  • 12 Answers
SOURCE: i have a samsung bn59-00599a remote for samsung
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Posted on Dec 15, 2007
SOURCE: SAMSUNG BN59-00599A REMOTE
http://downloadcenter.samsung.com/content/UM/200705/20070515083727984_BN68-01167A-01L02-0331.pdf
Pages 18-25 should be what you need.
Posted on Dec 01, 2008
SOURCE: need control code, to operate dvd samsung
Yes. I found the code. To operate Samsung HT-Z 310 with a remote control of Samsung TV, You have to turn off DvD, and then select Dvd on the remote(press the dvd button), press SET on YOU
remote control, input the CODE(020). For different Samsung dvd. you can try.codes from 000-to 080. The DVD button must blep three times. After that swich on Dvd. Enjoy....
Posted on May 05, 2009
SOURCE: my new amino remote only works on my tv and not on
Try re-coding the remote. Hold down STB and OK for a few seconds. Then when the red light is steady on the STB button you put in the code 000. By doing this you have reset the remote control. Also a good trick is to remove the batteries and put them back in. With that you are basically turning the remote off and on again. The good old restart.
Posted on May 07, 2010
I have a dick smith stb model number gh5930 and a Skandia URC need four diget code for remote
Codes are in the remote, not the STB. Use the code search feature of your Skandia URC to find something that will handle some or all functions of your STB. If a search through all codes in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
May 15, 2016 | Televison & Video
Code for Rank Arena STB
0092,0097,0927,0977 are the codes to check with this STB. If you wish to get more, 3 digit, 5 digit codes, check this link. http://electrohelponline.blogspot.com/
Jun 06, 2013 | Televison & Video
STB code
0382,0193,0118,0285,0146. Check these coded. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 14, 2013 | Philips Universal PH301S Remote Control
Code to connect Amino STB to Onkyo RC-834M
035,028,019,075,082,041. Check these codes. If you wish to get more codes, four digit, five digit, three digit etc: check this link.
Feb 26, 2013 | Onkyo Televison & Video
I need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
I need the remote code for the insignia sound bar to use with my verizon fios remote control
Jeff Phillips What I did was connec the soundbar audio directly to the Verizon STB audio out and changed the remote to control the STB volume instead of the TV. Then I plugged the soundbar into the switched outlet on the back of the verizon STB.
Nov 25, 2010 | Televison & Video
GE Universal Remote
here are the codes, 020,024,028,030,186,187,096,054....hope this helps....
Apr 27, 2010 | Universal Remote Control GE174Universal...
My new amino remote only works on my tv and not on my aminorouter. If a switch from tv to stb I can still use the vol button but the ch. button does not work. I cant change the channels on the amino...
Mar 22, 2010 | Philips PM3S Remote Control
STB with Magnavox remote (need codes) - Samsung #TXK2766
Did extensive checking and finally found out that the remote for Magnavox TB100MW9 analog/digital converter is not made for volume control. The channel changing buttons are half-way operable--sometimes yes, sometimes no--and to think they call this a remote! Therefore you must keep the other TV ready remote that you have been using (tape them together probably) for volume and mostly channel change. I know what Magnavox can do with these remotes - and you know how much more Magnavox I will be buying in the future. Nada, none,---from a very disappointed, frustrated customer.
Feb 12, 2009 | Samsung TXG2746 27" TV
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
Samsung TV Remote Control Logo
2,178 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
