I have bluesky blf1207 fra b1 y5 7131183000 m3 machine i do not know how to operate this machine proble when i put my cloths in machine and make start it move for some time fastly after 5 minute its stop automaticaly it dose not receve water and after stop completely plese send me solution of my problem thank
  • 38 Answers
SOURCE: Admiral washing machine MOdel AAV7000AWW On any spin will not drain 1st time through
is this machine induction motor or carbon brush if it is the inductin you need to be looking at the capacitor and if it is carbon brush then change them you will find them mounted each side of the motor and the capacitor will be @ the top under the lid near the pressure switch good luck
Posted on Jul 24, 2007
SOURCE: Kenmore Elite Calypso Wash Motion
Goto consumeraffairs.com and type in Whirlpool calypso washer and cry!!
Posted on Nov 08, 2008
MNTECH
  • 1543 Answers
SOURCE: Visible water level in front-load clothes washing machine?
Yes, it is normal. There is water in the machine. One of the big draws for this style machine is that they use much less water than top load machines. If you stopped the cycle and opened the door, dug down in the clothes, you would find water. The machine fills a small amount of water (below the level of the door) and tumbles. As the water is absorbed by the clothing, the water level drops, so the machine adds more to maintain the water level. This is basically how the washer figures out how big your clothes load is and how much water that load needs. (Of course most sales persons at the big box stores and Sears have no idea how this works)
If you'd like, try running a cycle with no clothes to see how much water is in the machine. (It's not a lot) Now remember this: Because there is so much less water use than a top load machine, you must cut way way way back on the amount of soap and fabric softener used. Use no more than one tablespoon of HE (High Efficiency) soap (even less if it is 2x or 3x concentrate) and one teaspoon of fabric softener per load !!!!!
This should be a Fix-Ya for your question. Thanks.
Posted on Dec 14, 2008
SOURCE: F&P Smartdrive 058 filling in short bursts then stopping.
I had the same problem today. shephonos 18 had the correct diagnosis. Out of balance micro switch seized. Situated under the main circuit board. Cherry electric Corp 0.1amp 125 volt sptd type switch. jaycar has them for under $4.
I un-seized it with some electrical cleaning spray, fixed itshort term, no worries.
Thanks Stephanos 18.
Posted on May 22, 2009
  • 97 Answers
SOURCE: Whirlpool washing machine makes grinding noise
Hello Friend, Your solution is a real quick fix. The problem you are having is very common, your motor coupling has broken and that is what's making the grinding sound, also in this condition it will always pump out the water. Go to your local appliance parts store and purchase a new motor coupler, your cost should be under $25. It's very simple to remove old and install new coupler. First remove two screws from control panel and tilt control panel backwords exposing area under panel. You will see a metal clip on each side of cabinet under panel. Remove these clips, and unplug wires from plug in on cabinet. Remove cabinet by lifting up in back and tilting forward. Once removed you will see the innerworkings of your washer. Lay washer on it's back and remove the two spring clips that hold water pump in place and remove water pump. Leave water pump hooked up just move to side out of your way. Then you will remove the two screws that hold the motor clips in place and just snap the motor clips off. Be sure to unplug the wire harness plug from the motor. Just simply lift the motor straight up and off of the transmission. There you will see the motor coupler broken and to replace, just pry old one off transmission and motor with large flat head screwdriver. You will notice that one half of coupler is attached to the motor and the other to transmission. In the coupler kit you will receive both pieces and the rubber center connector. Just replace all the old with all the new and your problem will be solved. Happy to help, Tim.
Posted on Jun 24, 2009
We have Konica Minolta bizhub 164 copier machine its showing c6101 error code how to resolve that error plz tel me
1 Turn OFF and ON the power switch. 2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary. 3 Check M3 for correct drive coupling and correct as necessary. 4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB.
Sep 15, 2015 | Konica Minolta Office Equipment & Supplies
How do i use the dryer feature on the bluesky 1207
http://www.manuals.club/document_order_init.php?search=bluesky%201207&doctype=1
Jun 19, 2015 | Washing Machines
I cannot print from my konia minolta c360 series machine. The error showing c3201
C3201 Description Fusing motor failure to turn
• The motor lock signal remains HIGH for a predetermined continuous period of time while the motor remains stationary. Remedy 1 Check the connector between M3-PRCB CN11 for proper connection and correct as necessary. 2 Check the loading status of the fusing unit drive, and correct the error as necessary. 3 M3 operation check PRCB CN11-9 (REM) PRCB CN11-12 (LOCK) J-6. 4 Change M3. 5 Change PRCB.
Dec 07, 2014 | Konica Minolta bizhub Office Equipment &...
Bluesky BLF 1060X user manual
can you take a picture
front ,side and the back plus may be the filter
Feb 08, 2014 | Washing Machines
I NEED A USER MANUL FOR THIS PRODUCT bluesky bmg900esl23
http://www.chung-sim.com/bluesky.bmg900esl23.html
Jul 02, 2011 | Microwave Ovens
It don't seem to be draining all the way on spin. cloths a little to wet after spin
there may be a restriction in the drain hose or the drain pump.some small piece of clothing or other foreign object may cause this restriction.i hope this has helped out please let me know how things go for you.
Jan 22, 2010 | GE Energy Star WCVH6260F Front Load Washer
Water is slow to come into machine, we have hard water. A Filter?
You might have sediment from your hard water built up in the water valve to the clothes washer. You might have to replace the water valve. These clothes washers do not have a filter in the for the water. Hope that helped,
XCEL Energy Repairman
Apr 28, 2009 | LG WM2233H Front Load Stacked Washer /...
BMW E46 M3 when i put the handbrake on the tele goes off
needs to go on the bmw machine to tell the computer not to turn tv off when handbrake applied, its a safety thing .
Good luck. Davelee
Oct 06, 2008 | 2006 BMW M3
Computer
Any formula in Excel starts with the equals sign ("="). This is how Excel distinguishes between formulas and literal values. Knowing this, you can create lots of formulas using the usual operators of +, -, * and / for addition, subtraction, multiplication and division, respectively. Please see the examples below.
Add 1 + 1: =1+1
Add the contents of cell A1 to the contents of cell B1: =A1+B1
Subtract 2 - 1: =2-1
Add the contents of cell A1 from the contents of cell B1: =B1-A1
Multiply 1 times 2: =1*2
Multiply the contents of cell A1 times the contents of cell B1: =A1*B1
I hope this resolves the question. If not, please let me know.
Aug 08, 2008 | Microsoft Computers & Internet
Excel help
Maybe this is what you need:
=IF(A1="toilet",(B1*2),(IF(A1="bread",(B1*3),(IF(A1="star",(B1*4))))))
this is called "nested".
You can put nested if function maximum 7. (for more than 7, we should make another "trick")
if you put toilet in A1 then come the value B1*2
if you put bread in A1 then come the value B1*3
if you put star in A1 then come the value B1*4
Note: SUM(F16*0.3) is wrong. should be only (F16*0.3) or if you want to do sum --> SUM(F16:F20)
Apr 01, 2008 | Microsoft Office Professional 2007 Full...
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
