Question about Aimpoint 10338 CompML2 4 MOA
Red dot seems to disappear when you move the sight right to left or up and down.
  • 243 Answers
You are simply moving the dot out of the field of view.
The Aimpoint is set up to allow you to hit now matter where in the field of view the dot appears. High, low, right, left, it doesn't matter. If you can place the dot on target, your bullet will hit where the dot appears. Too much angle away from the center will move the dot out of your field of view however, This is apparently what is happening to you.
Posted on Oct 14, 2010
I'm sure this will sound stupid, I just bought a rifle with a Tasco red dot scope on it and have no idea how to activate the scope. Any help would greatly be appreciated. Thanks
No, that doesn't sound stupid. It's always a good idea to get all the information before using firearms and their accessories, and I'm happy to help:
The large knob on top of the scope is the rheostat, which is used to turn on the red dot, and adjust the brightness. It can be adjusted from "1" (dimmest) to "11" (brightest). You'll have to be looking straight down the scope to see the red dot, since it is only visible when you're aiming. If you turn on the scope to the brightest setting, and you look through like you are aiming, and the red dot is still not there (or very dim) then you probably need to replace the battery. It uses a 3 Volt coin-style lithium battery, type 2032. Unscrew the battery compartment on top of the rheostat and put the new battery "+" side up. Then replace the battery cover, and you should be good to go. Turn off the scope when you're done to save the batteries.
Since you bought the rifle with the scope already installed, it's probably already sighted in, or pretty close to being sighted in. Adjusting the windage and elevation on the red dot scope works just like other rifle scopes. The knob on top moves the point of impact up/down, and the knob on the side moves left/right. For this model, each click of adjustment moves the point fo impact by 1/2" at 100 yds, 1/4" at 50 yds, or 1/8" at 25 yds.
Be safe, and have fun!
Jan 24, 2011 | Tasco 1x30 Red Dot Sight BKRD3022
When I turn the turrets they go in the reverse direction, WHY
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Thats just the way it works. Point your right index finger at a spot on the wall, and sight down your finger like looking at sights, then take your left index finger and pretend it is a horizontal cross hair above your shooting finger, then raise your left finger a set amount above the right, then move your hands back to the shooting position not changing the distance in between, using your left finger now as the sight. You will see your shooting finger is now pointing lower than before. This is now the new point of impact, lower not higher. Hope this is clear as mud and helps Fix Ya up.
Dec 30, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Parallax problem with trophy 1x32. dot moves when i move my head
it will silly? when you go to shoot put your cheek in the same place on the rifle stock or the point of aim will be off,
Nov 29, 2010 | Bushnell Trophy 1x32 MP Red Dot Scope 3...
NEED INFO ABOUT ADJUSTING WINDAGE & ELEVATION ON MY MILLETT SP2 RED DOT. I LOST OWNERS MANUAL &NEED TO KNOW WHAT EACH CLICK IS EQUAL TO AT 100 YDS
the best way to sight in your red dot is clamp your gun in a gun vice or work mate? so it cant jump about!!!!!!! look through the barrel at a post say 100yds away then tweek the red dot or croos onto this post,,then test fire the gun and tweek the scope till its shooting were it points,,easy,,,
dont let the gun move at all,,,,you need to remove all the wobbely bits,,your the bigest wobbely bit?
an im not being nasty,,,you cant tweek a scope hand held?
Nov 27, 2010 | Millett SP2 Compact Red Dot Sight 5 Min...
My tasco red dot is shooting low and does not seem
i bet you havent undone the screw clamp first? it has a locking screw to keep it set up on target plus the ajuster screws ,,,undo the lock screw then adjust it, but its a beast to set up,, when it is set up do up the lock screws and it throws it off again,,,
Nov 15, 2009 | Optics
The dot on my tasco red dot scope (BKRD30/22) fuzzy and is more smear than "dot". whats wrong here?
that is the problem with red dot sights.if your eye sight is not 20-20,you will get a star burst or halo.glasses will help.
Mar 19, 2009 | Tasco Scope Guide Quickly Zeroing Rifle...
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
Bushnell holo sight
It will test the condition of the batteries. Turn the sight on to its brightest setting and leave it for 2-3 minutes. Then while looking at the red dot, press the battry icon button and hold it in. If the image does nothing, you are good to go. If it starts flashing, then you have less than 20% left in the batteries.
Jan 13, 2009 | Bushnell ® HOLOsight
Sighting in red dot shotgun scope
Load your gun up and when you can shoot it, aim with your new glass(Scope) and lay out a group of three slugs, not buckshot, (i'm assuming your shooting a shotgun). Then use some trial and error to tighten your dot to your grouping. I don't blame you for the confusion, but normally, most scopes set up for this adjustment pattern are moving your target according to the knobs, not your crosshairs or dot. Another option you have is to buy a laser bore sighter. then you can play with adjusting your scope for in the field or wherever with much more comfort when you need to. You can find them online at walmart or almost any sporting goods store these days, yes they save ammo and yeas they save time, but i still shoot to make sure i'm dead on after using mine.
Oct 29, 2007 | Bushnell Sportsman 4x32 Riflescope (4x32...
Aimpoint 10338 CompML2 4 MOA Logo
458 people viewed this question
Top Aimpoint Optics Experts
rugby prop
 Brian Main
Brian Main
Mervyn Brooks
Level 1 Expert
Are you an Aimpoint Optic Expert? Answer questions, earn points and help others
