Question about Microwave Ovens
Servis m3094 automatic 900 w/machine manual - Microwave Ovens
What is the wattage
Wattage refer to the power level of the machine. The higher the watt number the more power full is the machine - for example a 900 watt microwave oven will boil water quicker than a 500 watt oven.
Mar 14, 2016 | Microwave Ovens
How do you set the power level
If you have a power level button---press it and then enter 1-0 for 10. Most microwaves automatically come on at power level 10 or Hi power unless you pick a different option like the defrost button which is usually power level 3.
Mar 31, 2015 | Westbend 0.9-cu. Ft. 900-watt Microwave -...
Not Heating
if ventelation fan lts work ok thats mean the problem in hv circuts
you must be have an ohm meter to test
http://031d26d.namesecurehost.com/mwd/kot-150_kot-151_kot-152_kot-155_sm.pdf
read this servis manual its good :)
Nov 25, 2013 | Hamilton Beach Microwave Ovens
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
I need an owners manual and recipes for the hitachi bread machine HB-D103
Check out this download link (pdf)~9.04MB @ http://www.manualsonline.com/mdownloads/a2ff9b61-1c99-425a-90cc-fd40cb97bfd2.pdf (HITACHI AUTOMATIC HOME BAKERY - HB-D102/D103(USE & CARE MANUAL & COOKBOOK)
It will take quite a while for the pdf file to open & you can save the pdf manual on the PC & print a copy out later.
Hope it is the manual you needed.
May 27, 2011 | Hitachi Microwave Ovens
Hi i have a problem with my servis m6725w washin machine it drains and fills but wont spin the drum at all
Motor brushes? Thyristor on control board? Belt broken? Not a lot else it can be.
Dec 28, 2010 | Microwave Ovens
SHARP R 383(SL) M
Hi - You can download the manual from the link underlined in blue below:
R-383
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 30, 2008 | Sharp R-383 900 Watts Microwave Oven
Microwave Ovens Logo
191 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
