Question about LG 47LC7DF 47 in. LCD HDTV
My 47' LG HD television worked fine yesterday and this morning the red light is just flashing. I just bought this television.
  • 3 Answers
I had the same situation with my 47" LG. I opened the back and found 3 bad capacitors (bubbled on top). I replaced them at a cost of $1.20 ea at Radio Shack. I'm no expert at replacing these, so I let you tube be my teacher. I saved myself over $200 by doing it myself, not to mention there are some dishonest people out there that'll lead you to believe your TV is shot.. See the pics below of the "bubbled/bad" capacitors. These shoud have flat tops..Hope this helps....My 47' LG HD television - 01b92fd.jpg
Posted on Oct 16, 2010
Whenever I turn the tv on it stays on for 10-15 seconds and then it turns off, a flashing red light also appears on the bottom right of the monitor. What is the issue?
Hi, That sounds like an issue with the board in the tv, can't say I've seen it happen with that model yet but I have with last years models. If it's too late to return it to the store where you bought it I'd suggest seeing if they'd exchange it for you if not talk to LG.
Jul 27, 2011 | LG 47 47LK520 47 LCD TV
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue light shows up and blinks when I power it on....But the screen stays black. No sound no nothing. Just bought this tv yesterday!
This tv have problems,the tv Tuner signal board, that the board,that take in the incomming broadcasting signal cable.This board,it dead.Call LG for the warrenty replacement of this board.
Oct 18, 2010 | LG 47LD520 47 in. HD-Ready LCD TV
Problem for LG 47LC7DF 47 in. HDTV LCD Television it just flashes red and takes a couple of minutes to turn on and makes a popping sound..
television just flashes red and takes at least 15 minutes to turn on after turning off and on and makes a popping sound.
Apr 24, 2010 | LG 47LC7DF 47 in. LCD HDTV
Flashing red center light
With most flat panel TVs, the TV turn itself OFF when it has a fail electronic part and the red light starts flashing. They call this "Protection Mode". The flashing red light should be a error trouble code.
But, it's weird that everything is working and the red light is flashing. Since you just recently bought the TV, I would get it check out while it's still under warranty. Better safe, than sorry.
Jul 20, 2009 | LG 26LX1D 26 in. LCD HDTV
NO PICTURE OR SOUND
Hi
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
You can buy a replacment lamp from here
http://cgi.ebay.com/NEW-DLP-LAMP-BULB-JVC-FOR-HD-61G787-HD-61G887-HD-61Z456_W0QQitemZ320274762989QQcmdZViewItem?IMSfp=TL0807151554r7572
Hope this helps
Cheers
Aug 10, 2008 | JVC HD-61Z456 Television
Sony FWD-42PV1 -
I diagnosed the same problem on my FWD-42pv1 as a problem on the Y-SUS board. The fuse on that board was blown, and the board itself was bad (replacing the fuse was not enough to fix it). The symptoms were exactly the same - the LED cycling red/green, and then finally stuck at red.
With a new Y-SUS board, the TV has been working fine for a couple months.
Jan 26, 2008 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Samsung HCL4715W will not power on
At five years old, I doubt it will be worth replacing the power supply , a picture tube or two and possible the signal board. Cut your loses and get a new set.
Aug 25, 2007 | Samsung HCL4715W 47" Rear Projection...
LG 47LC7DF 47 in. LCD HDTV Logo
843 people viewed this question
