Question about Whirlpool Microwave Ovens
I have a Whirlpool dishwasher that leaves soap and some food on dishes. It has been working fine for over four years. I have not change soap or loading metheds.Looking for a reason for this.
    President:
  • 2,468 Answers
Check the sump screens on the bottom of the interior of the unit in the pump area, then also the pump and food macerator knives in the pump for broken or bent blades and all drain hoses for food buildup that can slow drainage and lead to siphoning or food backwash back into the machine,you will need to remove the toe kick panel at the base of the machine to check the pump and macerator and drain hoses leading to the drain and garbage disposal if this is where it drains to,if these areas are plugged it cannot remove dirty water to rinse dishes correctly
Posted on Oct 10, 2010
GE dishwasher GSD6260JSS doesn't clearn as well as when new
water temp should be a minimum 140 degrees at inlet this can be checked with meat thermometer at kitchen faucet,also need proper fill of water entering dishwasher proper water pressure and fill also important for proper cleaning of dishes,if water is slow entering you may have sediment inside fillvalve screen if on well water in this case you will have to disconnect water supply line and take valve apart the screen is in side valve reassemble and test operation...if this does not work you may have to replace inlet vavle
Oct 21, 2012 | Microwave Ovens
Unable to eliminate odour from previous cooking despite the fact that I wipe the microwave with a soapy cloth & then with a clean cloth each time to Microwave is used
  1. Fill a plastic bowl with 1 qt. of warm water. Add 2 tbsp. of liquid dish soap and 1/4 cup of chlorine bleach to the water. Thoroughly mix the solution.
  2. Dampen a clean cotton rag in the solution. Wipe all inside surfaces of the microwave with the soapy rag to remove food debris and stains. Scrub stubborn residue with a nylon scrub brush.
  3. Moisten another cotton rag with warm water. Wipe the microwave surfaces with the rag to wash away soap and loose food debris. Thoroughly rinse the inside of the microwave.
  4. Dry the microwave's interior surfaces with paper towels. If odors remain in the microwave, fill a microwave-safe bowl with 1 cup of cool water. Add to the water 2 tbsp. of baking soda, half of a chopped lemon (including pulp and rind) and four whole cloves.
  5. Place a microwave-safe plate on the microwave turntable. Set the bowl on the plate.
  6. Heat the microwave on high for three minutes. Operate the microwave according to the manufacturer's directions. Keep the bowl in the microwave for 15 minutes.7
  7. Remove the bowl from the microwave. Wipe the microwave's interior surfaces with clean paper towels to remove steam moisture.
  8. Leave the microwave door open overnight to completely air out any remaining odors.
  • Sep 05, 2012 | LG LTM9000 Microwave Oven
    Will not heat
    If everything else is working fine, the magnetron is the likely problem, "heats food and is the heart of the microwave oven" if more than five years old cheaper to replace the whole item.
    Mar 02, 2012 | Whirlpool Microwave Ovens
    Not cleaning dishes on bottom even when half empty - leaving film. using rinse aid. ran two cycles with vinegar help
    I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
    Dishwasher
    Spray Arms not Spinning
    How to Buy
    Appliance Parts Online
    A bad heating element causes many problems in dishwashers...
    Dishwasher Problems The
    Heating Element not Working
    Dishwasher Maintenance
    Dishwasher Residue and Film on Dishes
    heatman101
    Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
    Aug 04, 2011 | Microwave Ovens
    While dischwasher is running, water are leaking from the front.
    Depending on the model, there are corner seals (kenmore are black) at the base of the door these can fail , Frigidaire, Galax, and Whirlpool/ Tappan use small plastic diverters that are semi clear.
    If these are missing in the corners nearest the base of the door then this problem
    will occur. Also if you are using regular dish detergent, it will oversuds. One last note,
    if the dishwasher has not been used for a while due to handwashing on the disposal side
    of the sink, the soap will make its way into the sump of the dishwasher and cause this
    condition. Try using several pitchers of water and pumping out the water by rotating the
    control knob till it pumps out to dilute the soap. Hope this helps.
    Jul 17, 2011 | Microwave Ovens
    Dishes are not getting clean particularly in the upper rack. The soap dispenser opens properly but the soap was still there. The washer seems to fill properly and it sounds normal. The dishwasher goes...
    Make and model?Is the water hot enough? Is this a new problem? Is all of the detergent still in the dispenser or do you use detergent both in the washer and the dispenser? Please reply to this inquiry for more help. Do you have the manual?
    Jan 07, 2011 | Microwave Ovens
    The microwave will not heat the food
    Yes - please buy a new one.
    Unfortunately microwaves have 2 positions - working or dead!.
    The cost to resurrect from the dead is all out of proportion with the cost of buying a new one which will have at least a 12mths guarantee
    Jun 08, 2010 | Frigidaire FMV156DC Microwave Oven
    GE Spacemaker XL 1400
    First, wipe out any excess crumbs. Then fill a microwave-safe bowl with about 1-2 cups of water. Add some lemon juice, or put in half a piece of fresh cut lemon (squeezing some juice out first) into the bowl... Microwave until the water is boiling. Then let it sit for a few minutes to let the steam penetrate the interior. Carefully remove the bowl and interior tray. Wipe down the interior with a damp cloth. Wash the tray in the sink with dish soap, dry, and then return to microwave. For the outside, spray with a kitchen cleaner and wipe with paper towels. The main idea is that the steam from the water will loosen food particles, and the lemon will add a fresh smell.
    Jun 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
    This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
    Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
    Microwave Ovens Logo
    Top Whirlpool Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
