Question about BYTECC BT-ECU2FW Expansion Module
Hi, I need ECU wiring diagram for my Seat Leon FR 2.0 TDI 170 BHP, many thanks
When driving my seat leon 2.0 ltr tdi after approx 2 miles the abs and tcs lights come on
what are the dtc codes at your abd control modules at adress 03? it might be pin outs corrosion at abs sensors, wirring harness , but before you have to check dtc codes using diagnostic tool
Apr 01, 2014 | Toys
Where is the fuel filter location on a seat leon s 1.4 litre petrol
The light is not due to any clogged filter issue, you have an engine fault in one of the sensors most likely.
Mar 21, 2014 | 2000 Seat Leon
Why does my seat leon fr flash 20mph and bleep when driving over 20mph
U HAVE ACTIVATED SPEED WARNING!!USE MANUAL TO DEACTIVATE!!
Dec 21, 2013 | 2006 Seat Leon 2.0
Seat Leon Fan Control
We do not have this make in the USA so have no info on it.
Jun 07, 2012 | 2006 Seat Leon 2.0
Pontiac 2000 Montana - INSIDE LIGHTS NOT WORKING. fuses are ok. I need a wiring diagram.
Hello Leon. The diagram may be hard to see. We are allowed only 150kb for a picture.
1.
2.
3.
4.
There you are Leon. All the interior lighting diagrams.
Thank you for using FixYa.
KL
Nov 19, 2010 | 2000 Pontiac Montana
My oil light keeps flashing on my seat leon fr 1.8 20 v turbo i've checked the oil and its ok any ideas?
hallo
check oil preassure (should be 2 bars/2000 rpm. at working temperature) if OK, check oil pressure sensor- change.
if not OK could be bigger problem (leaks, bearings, or turbine problem..)
marko
Dec 06, 2009 | 2003 Volkswagen GTI
Seat leon 2.0 tdi 170, driving car last night and vehicle just cut off, is cranking but doesnt start up, suspect something to do with fuel pump, can any on help..
check for spark if it cranks and wont start most likely u dont have spark , remove #1 spark plug wire and put a screw driver in it doin that touch ground crank it and see if there any spark jump to ground
Nov 14, 2009 | 2007 Volkswagen Golf
Golf gt tdi 2.0 140 bhp mk 5 - esp light
When there's something wrong with the brake pressure that handbrake warning light comes on.
The ESP warning light could be caused by a lot of things, but most likely it's a dirty fuel filter. Don't take my word for it though, just go to the VW dealer and have it read the faultcodes from the ECU, which should point you/them in the right direction.
Alternatively, when you have the right equipment (= VAGCOM + cable) and knowledge, you or a friend yould diagnose the ECU yourself.
From the sounds of it, you'll need a small service (air filter and oil filter change, etc.) anyways. Don't forget to reset the ECU (or dis- and reconnect the battery) afterwards to erase the faultcode from memory (when there's still something wrong, it'll return soon enough).
You might get lucky with a small service :)
Aug 07, 2009 | 2001 Volkswagen Golf
BYTECC BT-ECU2FW Expansion Module Logo
1,461 people viewed this question
Top BYTECC Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Raymond Lidington
Level 1 Expert
Tom Chichester
Are you a BYTECC Computer and Internet Expert? Answer questions, earn points and help others
