Question about Logitech LS11 2 Speakers
Light flickering and completely off after 40%-50% sound volume. Sound sounds "crummy" and distorted but it was fine when i first bought the speakers
jackboy
  • 2985 Answers
SOURCE: Computer stopped recognizing the speakers
Check the sound card system Can your hear through headphones for example?
Posted on Jul 24, 2007
SOURCE: my right speaker does not work
My left speaker didn't work, I described how I fixed it here: http://users.tpg.com.au/malydog/fixits/logitechx230.htm
Posted on Aug 14, 2007
  • 108 Answers
SOURCE: no sound out of speaker(the one with the volume control on it
I'm taking it that from what you're saying, the other speaker is working perfectly.
here are a few things you could try, if this is the case. You've probably attempted most of them, but it doesn't hurt to cover all your bases.
Turn both your speakers, and windows Volume Control up full blast. (while you're within the Volume Control window, it wouldn't hurt to check to see if the balance is off there, as well). Put your ear to the speaker, and listen hard- do you hear any faint hissing or crackling sound, like static?
If you do, then the speakers are working perfectly on their end. The hissing sound would be power going through them. this can only mean that there is :
a) a problem with the connection to the computer - fiddle around with the cable connecting it, twist it slightly in the socket and look for and *gently* bend any creases you may find back into their proper places, while playing a song. if at any point you hear the other speaker come on, you have your culprit. Also, try plugging a headset or spare set in if you have any, to eliminate the possibility it's a bad jack with the soundcard. if you hear both speakers on your headphones playing, it's NOT the card.
b)a problem with the software you're using to play sounds. again, open up Windows Volume Control, and check the speaker balance there. if the problem occurs only with certain programs, like Winamp or Windows Media Player, open up those programs and check the balance there.
If you, on the other hand, DON'T hear any sound coming
from the speaker in question, or if what happened above doesn't work, it could be a problem with the cable connecting the two speakers together. Play with the audio cable connecting to both of them for a bit, see if you can get them working by repositioning it, again while playing test music.
If the above solutions don't help, you could be looking at a blown speaker, and they may need to be replaced. if you do so, i'd recommend any one of the 2.1 (two speakers and a subwoofer) systems that Logitech sells. they are extremely simple to set up, and have excellent sound for a good price.
Posted on Dec 30, 2007
IrishDruid
  • 2712 Answers
SOURCE: sound from 4 speakers cut off..
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 24, 2008
AldRezaine
  • 995 Answers
SOURCE: My right speaker will not output any sound.
Reconnect all the wirings of the speaker set. Left and Right sound connectors from the subwoofer properly.
Posted on Nov 03, 2009
Testimonial: "Everything is plugged in properly. I've replugged and still nothing, still out. Headphones right piece is out in the remote but not in the comp"
Subwoofer distortion with low volume
We need to know what the amp is and its model, what the speakers are, what the enclosure is.
Jan 18, 2018 | Rockford Fosgate Audio Players & Recorders
Bose L1 Speaker Distorting
See this article on the inputs on the Bose L1®.
L1 Model Bose L1 Encyclopedia FAQ Wiki
Set the trim levels so that lights are solid green with occasional flickers of red.
Mar 15, 2012 | Bose L1 Speaker
I bought a system and this scosche fa1-3a came with it and I have no idea what its for please help
This device is used to connect the speakers out puts to an amplifier.
Usually a car stereo speakers are high volume out puts and it can damage the sound (distortion) at the time to connect an amplifier so the best way with less distortion is hooking up this device to low the volume and get a clean sound to be amplified
Dec 03, 2010 | Scosche Industries Scosche Slc4 Speaker...
The two speakers dont work.One of them does not
check the cable may be cable from first mall speaker problem
May 13, 2010 | Altec Lansing BXR1121 2 Speakers
I have to have the voume at 30 to get good sound
Try going into the menu and selecting the sound menu and resetting the sound to factory default..If this doesnt help matters you can change the sound preferences to custom settings..As long as the sound isnt distorted at low volume then this solution will apply..If the sound is distorted at low volume then your speakers may be faulty..sometimes caused by listening to the tv at full volume over long term which strains the speakers and prematurely ages them
Oct 17, 2009 | Samsung HP-T5044 50 in. Plasma TV
Asus A8N32 SLI Deluxe Motherboard audio problem
The new boards multiplex the connectors on the back panel to maximize use. Open the Realtek control panel and configure for sterio 2.1. Also, these new boards do not provide any power drive, so to get decent volume, you will need amplified speakers.
Oct 09, 2009 | ASUS A8N-SLI Premium Motherboard
Inspiron 530 sound distortion
What kind of integrated sound card do you have?? I am going to assume its realtek. Go to control panel, then open up RealTek HD Sound effect manager and make sure the drop down menu for Environment is on "none". The try your speakers.
Mar 25, 2009 | Dell Inspiron 530 Desktop Computer
I am geting a distorted song in my computer speakers
What do you mean more exactly by "sound like if the computer freeze"? If you set wave or master volume on your PC too high, the sound card or the speakers may get overdriven, which results in distorted sound. So you could try lovering the voume in your PC, and set it higher on the speakers. (On the contary, if you set volume in your PC very low, and very high on the speakers, sound will get noisy.)
Mar 19, 2009 | Audio Players & Recorders
JVC DVD player plays with distorted sound
Have you tryed a differant audio input on another set or on that same set. Are the audio cables good?? If all this is ok then the D/A converter inside the unit is defective and most likely it wont pay to repai sorry
May 25, 2006 | JVC XV-N40BK DVD Player
Logitech LS11 2 Speakers Logo
136 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
