Question about Maytag Neptune MAH5500B Front Load Washer
Neptuen washer stopped working in mid cycle. "do" light comes on but the door indicator light is not lit yet the door is locked. after a minute the "FL" light indicator comes on. the door is locked and has water in the tub. turning off and on, after it cooled all night, made no difference. it tries to fill with water and then gives the "do " indication again....after trying to fill. this is a Neptune model purchased in -91
    President:
  • 1,554 Answers
The problem is with the door locking mechanism and the only viable solution is replacing it. Drain the water from the tub manually by placing the end of the drain hose into a bucket or a shallow basin. Position the bucket or basin as low as possible to drain as much water from the tub. Once the water is drained, the door can be unlocked using the door lock emergency access cord under the dispenser bezel.
Disconnect power then
open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off to access the emergency access cord. Pull the emergency access cord carefully and steadily then open the door.
The top cover with the dispenser bezel off can be lifted to the rear of the dryer to access the door locking mechanism, but you have to remove the front panel first. Disconnect power to the machine prior to servicing to avoid the risk of electric shock.
Open the machine door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel then move it away and set it aside.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracneptuen washer stopped working in - 93ee117.jpgimg src="http://i.fixya.net/uploads/images/93ee117.jpg" alt="93ee117.jpg" class="h_mi" />
Swing the bracket to the outside and unhook ineptuen washer stopped working in - 67a7d37.jpge slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the machine. The door locking mechanism can now be removed and replaced.. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Posted on Oct 10, 2010
Everytime I start the washer it pauses halfway through the cycle why is that
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
Sep 28, 2016 | Washing Machines
Aeg protex how to open door mid cycle
To open door during mid cycle, turn off washer by plug and wait a couple of minutes until you hear a click, then the lock light ( assuming it has one ) will release, but make sure there is no water in the tub before opening the door. If possible when door is unlocked, run the drain setting and let the water pump out before hand. Hope this helps.
Aug 16, 2014 | AEG Washing Machines
The water starts to come through then just stops and then alarms go off
see this causes and fix it. God bless you
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Oct 05, 2012 | LG WFT1071TP Top Load Washer
My maytag epicz will run water and then just stop it lock and later get code f33
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Oct 05, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Not doing cycles
see the diagram attached.
Sep 30, 2012 | Washing Machines
Washer stops at rinse cycle and give the ul code F1
Sep 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag washer stops in mid cycle
have a front load mah9700a. Unit will not run door is locked , have found that control board shorted. Still need to open door manually, need a parts scheme to look on how to open????
Sep 03, 2008 | Washing Machines
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
